206cc to a 308cc How ? Why ? Everything 308cc
Huskyxantia
- x 927
Re: 206cc to a 308cc How ? Why ? Everything 308cc
For reference part number for 308cc front lower balljoint
Husky.
Huskyxantia
- x 927
So new ball joint is in 90nm toqure setting hub , and all brake parts are in the car boot as im now waiting a new drive shaft I can confirm the on the car even scared ai , I showed the ai on my device via camera all movement and it came back with for your safety do not drive your car from what im seeing and how much floppy free play you are showing me it is very dangerous this has caused your inner tyre to wear plus the lower ball joint too... well, I got told off ......
Some photos of the shaft out of the way and some gearbox numbers as one seller claims the driver shaft is coded to the gear box ? What for ...
Husky.
Huskyxantia
- x 927
It did till it turned out to be a tad over 1mm to thick for the roof to close correctly, so its been done again in a grey soft cloth proper thickness too and a happy roof
Husky.
Huskyxantia
- x 927
Classic! Mind you, I haven't seen anything get jammed that badly by an extra couple of mil since my last drunken Saturday night." ... exit stage left lolmickthemaverick wrote: 23 Aug 2026, 18:19 The thickness of liners has been a consistent concern since 1912![]()
Husky.
- x 2366
Just checking: this isn't the torque setting you've installed that big 41mm ball joint into the hub at is it?
Haynes 308 figures for you:
- x 8427
You've been busy Husky! As regards the little Torx screws holding brake discs to the hub: I always use a small impact driver to remove them. It that fails, they're easy to drill out...
Huskyxantia
- x 927
I thought it was more than 90 .. its not back on the car yet so when it is I can pound it up , ive another problem. Where the hell is the gearbox number on the gearboxMattBLancs wrote: 31 Aug 2026, 08:47Just checking: this isn't the torque setting you've installed that big 41mm ball joint into the hub at is it?
Husky.
Huskyxantia
- x 927
Turning into a puzzle this one found 2 drive shafts but the seller is asking vin , reg , gearbox code .... digging around the gearbox now wheres the number ...CitroJim wrote: 31 Aug 2026, 10:09 You've been busy Husky! As regards the little Torx screws holding brake discs to the hub: I always use a small impact driver to remove them. It that fails, they're easy to drill out...
Husky.
Huskyxantia
- x 927
Found these numbers and that's it no others
Husky.
Huskyxantia
- x 927
I think this is the gearbox code .
Husky.
- x 2366
I'm not certain, but think "9HR" and "RGH" are engine codes - if I'm correct they should be part of your car's VIN number. Characters 6,7,8 should match:
https://en.wikibooks.org/wiki/Vehicle_I ... /VIN_Codes
Huskyxantia
- x 927
Ive just messaged the seller , we'll another seller they only needed the vin so fingers crossed this is all that's needed , the only difference i think they might be getting fussy over isMattBLancs wrote: 31 Aug 2026, 20:46 I'm not certain, but think "9HR" and "RGH" are engine codes - if I'm correct they should be part of your car's VIN number. Characters 6,7,8 should match:
1 petrol drive shafts are not intended for diesel
2. 1.6hdi and 2.0hdi shafts are compatible
3. 5 speed box or 6 .
Which mines a 1.6hdi 6 speed , I'll just wait and see what this other seller comes back to me with.
Husky.
Huskyxantia
- x 927
Not a very productive day at all , I measured the drive shaft it was bigger than 2 numbers ive been given regarding drive shafts for the 308cc so I went to the main dealers and was met by a big grinning bearded chap who quickly said how they no longer handle parts , I had to go to the other part they are now under a mile up the road , gave me directions and off I went , well this was great in I went into this big massive unit , I was met by your typical English chap .. vejay ... i put forwards what I needed and quickly was told NO we can't give you the OEM numbers were not allowed.
So off he went then I spoke to another chap who used to work in the service part to the original dealership , he told me now they have to give the car keys back to the owner while they then have to cut a new one and programe it then sell it to the owner of the car because its there rule now???
Just opposite was Euro car parts whom can be useless so I went in there , they did give me a part number and price , £386+vat
Place before .. look at the photo , ive just about had it today 4 hrs of waste trying to get a drive shaft and im no better off...
Husky.
PaulC5
- x 702
I would try Peugeotpartsdirect for a price. They have the same contact phone number as CitroenDirectparts who when they give a quote have also given the parts diagram with the part number (top right SKO number) https://peugeotpartsdirect.co.uk/contact-us/
- x 1083
Online Automotive is worth a go.
Champion of Where's CitroJim
