C3 Picasso Clutch Issues
Huskyxantia
- x 930
Re: C3 Picasso Clutch Issues
Its a bit confusing Jim when you read its gravity that bleeds these .. id say with a little help from , this..
Pressurise the sytem then pull out clip net to nipple pull fluid feed pipe part out let fluid out keep fluid bowl topped up , if air is in the system your see it in the pipe connected to the bleed nipple & collection bottle. Sounds like a plan to me.
Husky.
- x 8453
Yes, that would do the job.. A bit like to old Gunsons Eezi-Bleed system that used pressure from the spare wheel to achieve the same... It worked rather well...
Huskyxantia
- x 930
Mick that is a brillant idea and i will certainly do it . Seeing how cheap looking these pipes look i reckon there must be some perishing going on somewhere.
Husky.
Huskyxantia
- x 930
seen someone on youtube do that , works a treat. Im getting rather excited now to get out to the car lol but its dark & my teas almost ready so in the morning the task will be slowly set in motion.CitroJim wrote: 02 Dec 2024, 17:37 Yes, that would do the job.. A bit like to old Gunsons Eezi-Bleed system that used pressure from the spare wheel to achieve the same... It worked rather well...
If not shall i get a nisssan cashcow ?
Husky.
- x 8170
Still does, I have it in the garage as my goto bleeder!!CitroJim wrote: 02 Dec 2024, 17:37 A bit like to old Gunsons Eezi-Bleed system that used pressure from the spare wheel to achieve the same... It worked rather well...
Onlinemyglaren
- x 5688
On none-hydropneumatic cars I have found these to be a very simple and effective solution, only needs one person to operate it.Huskyxantia wrote: 02 Dec 2024, 17:12 Bleeding .
1. 2 man one opens the nipples while other pumps pedal
2. 1 man , using vaccume procedure.
3. Combo of 1&2
4 give up .... go electric ...![]()
Embarrassingly cheap.
Huskyxantia
- x 930
Ive seen something like this its a one way valve thing isnt it. I had a pipe with a ball bearing in a plastic end which let fluid out then close by the ball closing the hole.
Husky.
Huskyxantia
- x 930
Sometimes simple is best.
Husky.
Huskyxantia
- x 930
Love this site it can be useful , but also out dated for some
https://www.wikihow.com/Bleed-a-Slave-Cylinder
Might be useful for someone so ive popped the link here.
Husky.
- x 8453
That's it... Got one here. The trick to get the best out of it is to have the one way valve submerged at all times in a jar of clean brake fluid... Then, rather than any tendency to suck air, it'll suck fluid instead...Huskyxantia wrote: 02 Dec 2024, 17:55 Ive seen something like this its a one way valve thing isnt it. I had a pipe with a ball bearing in a plastic end which let fluid out then close by the ball closing the hole.
Huskyxantia
- x 930
Ddclutch has a sort of part clutch bleed thread going on which relates to here.
viewtopic.php?t=76429
might be useful for someone one day.
Keywords * painintheharsec3picassosillyclutchdesign. #plastic with heavy load to bear
Husky.
Huskyxantia
- x 930
Todays findings .
First thing i did was made sure the fluid level was topped up ,it was
Then i popped the master cylinder plunger back onto the clutch pedal
I then fitted clear pipe onto the slave cylinder bleed point , made sure the clutch pedal was fully up, unclipped the clip next to the bleed outlet pipe in the slave then pulled the pipe to allow the air & fliud to run out. It came out down the tube into my bottle with some fluid in and pipe submerged , then the fluid ran clear. Fluid pipe to slave cylinder then pushed back home and the clip also pushed home to, i went to try the pedal , met with a hissing sound and hardly no pedal , then pedal laid flat to floor.
So wiper scuttle panel off, air box out , BINGO , Master cylinder supply pipe
Was leaking at the master cylinder connection point. So i pulled this off , no effort at all & ive poked it into the fluid filler bowl so it dont leak.
So this is drawing in air everytime the clutch is being used ,possible car movement & vibration wont help a week spot either.
Husky.
Huskyxantia
- x 930
This is a possible cause
Husky.
Huskyxantia
- x 930
The fluid feed pipe end didnt look to healthy to be honest.
Husky.
Huskyxantia
- x 930
A bodge fix with these...
Husky.
