Peugeot 407 Automatic gearbox oil change
mejt1987
Unread post by mejt1987 »
Hi guys, as im owner of one old 2005 peugeot 407sw 2.0 diesel, im slowly fixing broken stuf on it, but first i want to doo prior maintance, i want to change in next week or 2 oil and oil filters of engine, but doing that i want to change oil in gearbox to, my question is where could i get info what oil goes in it, its automatic 4 speed gearbox, and its working fine while driving, only what i saw as wierd was, that when i change from parking to R and to D then R it kicks a bit, like whole car kicks a bit, my gues is that in this 240 000km car has on it, oil in gearbox was newer changed.......Any sugestions, and please i need info regarding the oil in gearbox, i found some info that Lt 71141 goes in it, can i usse this OIL " https://www.auto-doc.at/liqui-moly/2451891" or what, and is it posible to change filter in this gearbox by my self...
PS
From PP2000 im geting reading that its 4HP20 automatic gearbox in my car....VIN is VF3**************[VIN obfuscated, can be read by forum staff] ; so if someone can check for me would be nice....thnx in advance...
mejt1987
Re: Peugeot 407 Automatic gearbox oil change
Does anyone have answer, i realy dont want to destroy my transmision completly?
x 3296
I am aware (from my time on the forum) that the LT71141 oil seems to be the correct oil to use in some PSA gearboxes. Other oils that purport to be suitable tend not to be suitable. I cannot say more than that, as I have never had an automatic car.
However, CitroJim (who is a member on the forum but (for medical reasons) has 'gone quiet') wrote up a guide on rebuilding some gearboxes, including an automatic one. It could be worth taking a look at his website;
http://www.eastment.net/
mejt1987
Hell Razor5543 wrote: 07 Jun 2021, 18:11 I am aware (from my time on the forum) that the LT71141 oil seems to be the correct oil to use in some PSA gearboxes. Other oils that purport to be suitable tend not to be suitable. I cannot say more than that, as I have never had an automatic car.
Problem is that here where i live in Austria, only oil that i get when i search for LT71141 is that LIQUI MOLY Top Tec ATF, 1200 Automatikgetriebeöl , but what bothers me is that in description it says BMW LT 71141
I ordered it as i need to doo oil change urgently in next 2 weeks so i hope i dont destroy my gearbox with it...
x 5672
mejt1987
myglaren wrote: 07 Jun 2021, 22:04 Try searching for Mobil LT71141
https://www.mobil.com/en-gb/passenger-v ... f-lt-71141
This should be it? https://www.motointegrator.at/artikel/1 ... pMQAvD_BwE
I canceled my previous order and ordered 5L of mibil.....as i plan to change oil 2 times in next month...
x 5672
That certainly looks like the right stuff.
Used to be Esso but changed to Mobil a few years ago.
The Mobil stuff is definitely correct for the PSA boxes.
mejt1987
myglaren wrote: 08 Jun 2021, 18:31 That certainly looks like the right stuff.
And i need to put out as much as posible of oil and pour in same amaunt, or is there way to check corect level...becouse oil is not changed or checked in last 240 000km so probably mising a bit...any right procedures for this work...im going to change engine oil, filters, shield under car disapeared so i ordered new one etc, bunch of work, so then i will be doing the gearbox too....
x 5672
I'll delve into it later, unless anyone else has the details but basically measure the amount drained, usually 3L, and replace with exactly the same amount.
This has to be done with the oil at a specific temperature ~ 60? IIRC.
The change has to be recorded in the (gearbox ECU) with a Lexia.
Repeat after a couple of thousand miles, then again after another couple of thousand miles.
There is a total of 7L in there but only 3L approx can be drained, the remainder resides in the torque converter.
x 5672
Here are a few threads dealing with it:
Some links no longer active. Unfortunately it seems that the links for the official procedure are to Jim's site, eastment.net and although some of it is accessible, that section seems to have gone.
Unfortunately Jim is currently not active on the forum but when he is I will point this out to him and see if it can be resurrected and possibly the procedure placed in out "How To" forum.
Do have a read of those threads as it highlights the many pitfalls that can be encountered.
Will continue to try and locate the correct procedure.
https://www.frenchcarforum.co.uk/forum/ ... 41&start=0
viewtopic.php?t=37027
viewtopic.php?t=30701
viewtopic.php?t=28274
viewtopic.php?t=31322
viewtopic.php?t=34847
viewtopic.php?t=21863
x 5672
Found these which I hope will be helpful.
I realised that you haven't mentioned which gearbox you have and there may be different procedures depending on the specific one.
If you post your VIN then we may be able to determine which one you have, if you don't already know.
https://autocarsrepair.com/transmission ... fluid.html
https://www.peugeotforums.com/threads/a ... ge.342802/
mejt1987
myglaren wrote: 11 Jun 2021, 20:37 Found these which I hope will be helpful.
I think its 4hp20 but here is my vin VF3**************[VIN obfuscated, can be read by forum staff] , from tomorow i start my project on car, all is ordered and came and now only my part :D
x 6945
Ok, so a bit late here, but you have a BVA4 HP20 (AG). This guide may help you.
Capacity is 8 litres in total (from new), but only approximately 3 litres are removed when draining.
Note there is a checking procedure detailed first, then the Draining & Refill Procedure below that will refer back to the Checking Procedure!
Tooling
You will also need access to Peugeot Planet 2000 Diagnostic Tool / Diagbox.
  • [1] Filling assembly (-).0341.
  • [1A] topping up cylinder (-).0341-A.
  • [1B] 4HP20 adaptor without gauge (-).0341-B.
  • [3] Pliers (-).0170-Y.
ESSENTIAL: Use only ESSO LT 71141 fluid.
Checking Procedure:
Prior conditions:
  • Check absence of faults using the diagnostic equipment
  • Place the vehicle on a lift (Vehicle level)
  • Gear lever in position P (Without handbrake)
  • Major power consuming equipment disconnected
  • Connect the diagnostic equipment
  • Select the parameter measures function
  • Ensure, before starting this operation, that the oil temperature is below 55 degrees C, if it is not, allow the oil to cool
  • Depress the brake pedal
  • Start the engine (Idling speed), Take the gear lever though all the gear change positions, return to P
Engine running: At a temperature of 55 ± 1 degrees C, open the oil level plug (3).
Wait for the temperature to reach 60 ± 1 degrees C.
1st possibility:
The oil flows: the level is correct.
  • Refit the oil level plug (3). (Tightening torque to 2.5 da.Nm)
2nd possibility:
The oil does not flow:
  • Add 0.5 litre(s) of oil (Refer to chapter: Refilling)
  • Resume the checking procedure for the oil level
Refit the metal part of the breather (2) using a 18 mm diameter punch and a hammer.
Clip the plastic portion of the breather (2).
Drain & Refill Procedure
Prior conditions: Draining to be carried out when hot to eliminate impurities suspended in the oil.
Draining is partial because the converter cannot be drained completely.
On draining, approximately 3 litre(s) are removed.
Drain plug (1).
Tighten the cap (1) to 4.5 daNm.
Refilling
Place the vehicle on a lift.
Release: The air filter assembly.
ESSENTIAL: Leave the air temperature sensor connected.
Remove: The breather assembly (2) (Using tool [3]).
Raise the vehicle.
Remove the oil level plug (3).
Using the tool [1], pour new oil through the breather hole, until it runs out of the oil level hole.
Start the engine: Idling speed.
Depress the brake pedal: Take the gear lever though all the gear change positions, return to P.
Add oil until it runs out of the oil level hole.
Close the oil level hole.
Stop the engine.
ESSENTIAL: Check the oil level (Refer to section above "Checking Procedure" ).
mejt1987
I found that same guide and went with it, only problem was that i was doing it on ramp so car was bit on angle, so i ended up pouring same amaunt that came out, gearbox already feels beter trought gears etc, kicking when switching from D to R is not so much as it was before....hmmm but i ended up now in doubts, i have next 2 big problems....Some idiot who was changing engine oil before i bought car, striped the oil bolt, so now i cant remove it to change oil, and second by my toughts HUGE problem that i figured out now, is that when i remove Oil cap from engie , it does not have vacum, instead it blows air out....what you guys say what im looking at, new car engine,,,etc...???
