which one do I have?
can i change the flluid? (working perfectly but at 103k think would be good idea)
which fluid does it use and how much? (price and quantity)
c5 2.2 hdi automatic mk 2 gearbox questions
- x 1056
- x 5674
Take a gander at this thread.The only fluid for a 4HP20 (and AL4) is Esso LT 71141. As you say, golden and smelling vaguely of cat's pee.
Also Jim's Excellent Autobox Adventures
- x 8391
Absolutely. Only ever use the pukka Esso LT71141. Nothing else is suitable. The Esso stuff is made from essence of cat and this will be obvious when you smell it! It's a rich golden colour is known as liquid gold on account of the cost of it....
You can order it from various on-line sources such as Automatic Choice but it is only available in 20L or 205L drums. 20L costs about £130 (ouch)
You'll only manage a partial change as half the oil is trapped in the torque converter and will not drain. Reckon to drain about 4.5 litres. To ensure a full change, do at least three partial changes at shortish intervals.
There is a special procedure for refilling and checking the level, for which ideally you need a Lexia to measure the temperature.
Be careful not to overfill as it will leak out of the driveshaft seals.
Here is the official procedure for draining and checking level.
Citroen and Peugeot dealers sell the oil in 2L bottles under part number 9736.22.
It cheaper, bearing in mind the need for the partial changes, to get a 20L drum.
mooseshaver
Hello this may be nonsense, but I found this "Update to note that Valvoline MERCON V is also a confirmed suitable ATF for ZF trannies. (manufacturer statement)
" On this website
http://www.taligentx.com/passat/maintenance/atfchange/
Its aparently olis that can be used instead of Esso Liquid Gold.
" On this website
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
hirsty
- x 9
Reading the letter from the Technical Director of Valvoline please be aware that although it can be used as a replacement i.e. total changeover of transmission fluid, they do not recommend mixing with Esso LT71141. If this is the case, can the box and torque converter be totally drained without removal?
Keith
Keith
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
- x 8391
No, not a chancehirsty wrote:If this is the case, can the box and torque converter be totally drained without removal?
All this oil retention makes them very messy to dismantle and work upon.
To drain totally would mean a full strip, new filter, a rinse out and a new torque convertor.
Makes LT71141 look cheap!
cachaciero
- x 9
This company apparently sells Lt71141 in 1 litre containers mind you have to buy 12.
www.oil-store.co.uk/Mobil-ATF-LT-71141-518.html
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
