Head Gasket and head repair
hungryhound69
Hello,
I had a failed head gasket on a C3 1.4 2008. I am trying to figure out if I can save my head or get a reconditioned head. I haven't yet measured the head for straightness as I need to get a straight edge first. However, I did measure the head thickness and it comes out at around 110.9-111.0 mm which suggests that it has already been skimmed once. I can get a reconditioned head and told I need a 2 notch gasket (I think that's a 1.4mm gasket-I may be wrong). But I also have seen 1.6mm gaskets so I am wondering what are they for. I am attaching pictures of the perished gasket I took off as it has 2 notches but I though the notches need to be closer together and one of the notches is some sort of registration.
So my questions are:
1. If my head passes the straightness test what thickness gasket should I use?
2. If It doesn't can it be skimmed any more or is it at the limit of usefulness as the factory specifies 111.0mm to be the minimum head thickness.
Thank you all in advance
- x 2006
Re: Head Gasket and head repair
I think you are correct that that is a 1 notch gasket.....BUT, see below
I would not trust measurements "done at home" for either warping or thickness, take it to a professional for checking and advice regarding the gasket to use.
Eling (OEM supply)
Eling (OEM supply)
hungryhound69
I was going to check the warping just to see if it was badly out of true and then take it to the local engine rebuilding workshop. But since then I clean up the corners and measured the head thickness with callipers. On the 4 corners I got 110.5/110.6 and on the other corner 110.7/110.8 so either my callipers are rubbish or it has been skimmed one before but then how did the car work without the valves hitting the cylinder heads with a one notch gasket or there is sufficient clearance. Before I take it to a specialist I want to know what I'm talking about and whether the head is even worth skimming. I though the limit is 111.0mm and you don't skimm after that.
hungryhound69
PS I looked at that Eling gasket you posted, it's a 984.136 a 1.27mm thickness. But the 117.831 listed as +0.2mm repair grade is 1.47mm and it has 2 notches similar to what I have but what confuses me are the 3 notches in the middle of the Eling gasket witch are present in both the 1.27mm and the 1.47mm
- x 2006
I just used that image to show the notch layout....not sizes.
ozvtr
- x 256
There are only 2 sizes. 1.2 (stock) and 1.4mm (repair). Plus or minus 0.1mm. So 1.1 to 1.3 stock and 1.3 to 1.5 repair.
This picture explains what the other notches are for.
I'm not sure that a new head is economical. I have found that the exhaust valves tend to get pitted and need to be reground anyway. So a "valve job" will need to be added to the cost of the head.
It's hard to say. The valve seats might need to be replaced. That will bump up the cost of a repair.
I don't know how much your machine shop guys charge!
I got the head skimmed, valve regrind on the inlet and exhaust valves and new exhaust inserts for $500AUD. That's about 300pound. I think I got a good deal!
I would recommend that you strip the head down to the head and valves. Then take that to a machine shop. See what they have to say.
Don't even think about putting the old head back without a machine shop looking at it!!!!!
The TU3JP cylinder heads turn into bananas if you over heat them. There are two reason why the head gasket fails. 1) the engine has over heated for one reason or another and the head is no longer flat. 2) the triangle shaped oil seal in the gasket fails and you get oil in the coolant or coolant in the oil.
I have replaced three TU3JP head gaskets in three different cars. The first one I DID NOT take to the machine shop. I am now getting coolant in the combustion chamber!! But I didn't know better at the time.
ozvtr
- x 256
So to decode the head gasket notches, a 1360 capacity engine will have a notch at "1".
No head gasket should have asbestos, so the "C" notch should always be there.
Looks like ELRINGs' supplier code is a notch at "A" and "B". I would ignore the A and B marks (supplier codes) as they are not really relevant to us.
Stock thickness (1.2mm) has NO notch at "R" but a notch at "R" is 1.4mm (repair) thickness.
Remember, the manufacturers have a 0.1mm tolerance. So ELRINGs 1.27mm stock and 1.47mm repair spec are within limits.
hungryhound69
Thank you ozvtr.
I was confused by the perished gasket I peeled off the engine block (pictures above in initial post) as it only had one notch in the thickness indicator area and I though there should be 2.
I wasn't going to use the old head if I could help it at all. I cleaned it up and measured the thickness of the head. All the values are below 111.0 at around 110.7-110.8 so it deficiently cannot be skimmed any more. I wasn't going to get a brand new head but look for a re-manufactured one that hasn't been skimmed beyond the spec from a specialised engine rebuilding machine shop. Although there are some aftermarket gasket at 1.6mm (AJUSA 10155610) but I'm not sure how safe that would be to skimm my old head even more. Definitely not recommended by Citroen. I suspect that it has gone banana shape since I had a catastrophic failure whilst driving. Loss of power, white smoke out of exhaust and engine cut out. When I had the car towed to my house and I started to take it apart there was very little coolant left to drain so it definitely severely overheated. So first I check it with a straight edge if it passes then I'll take it to a engine rebuilding shop to get a proper test but if it is warped, as seen by a home test, then no point to do anything with it. And maybe no point doing anything with it even if it isn't warped as it been shaved too much.
ozvtr
- x 256
It could be possible that whatever you are measuring the cylinder head with is not accurate enough?
You will also need to find a suitable reconditioned cylinder head, if you are going down that route.
Here in Australia I would have absolutely no chance of finding a reconditioned head! I would have to buy a whole, used, engine! Even in that case, I would pull the cylinder head off, recondition the head, and replace the head gasket! I would NOT put the used engine in without getting the head done.
Please let us know what happens.
hungryhound69
Hello Ozvtr, I now measured the head with a DIN 862 certified digital calliper. And indeed it is at 110.56mm so my cheap Chinese vernier calliper wasn't that far off. I also managed to get a reconditioned head for 390 EUR from an engine rebuilding specialist and that is about 110.64mm so again under factory specs. But I put a 500mm straight edge on it and it is flat to better that 0.02mm so good enough for flatness. However, if one looks at the French forums people routinely, almost de rigueur, undercut the head to squeeze 1-3 extra horse power. Those who don't want extra power just put a thicker gasket. So I think I will go with the AJUSA 1.6mm gasket. Seems that is common in this part of the world with old cars using TU3JP engines. But I ran into another possible issue. According to factory spec the liners need to protrude 0.03-0.1mm above the deck. I don't have a proper dial gauge with a bridge so I used a straight age and feeler gauges. So across all the liners I do mange to get a 0.03mm gauge under the straight edge and the deck and all the liners are on the same level to better than 0.02mm. But measuring across individual liners only cylinders 1 and 2 lets me get the 0.03mm feeler gauge in while 3 and 4 don't. Cylinder 1 being the one next to the camshaft pulley. So now I'm trying to determine whether it's my method, as it well may be without a proper dial gauge and a bridge, or my liners are indeed low. All the YouTube video I watched people changing head gasket from catastrophically overheated engines with even the valves slamming into the cylinders didn't measure the protrusion so I'm wondering how important that is. I would think it's important as the liners must seal against combustion leaking into the cooling system.
ozvtr
- x 256
The TU3 engines have been around for ages and the "bottom end" seems to be bullet proof.
The cylinder heads and head gaskets, however, are its Achilles Heel!
These are the first "wet liner" engines that I have had to deal with. The first and second engines that I did the head gasket on, had the liner protrusion according to the spec. As I said, the the first one is now leaking combustion gases into the coolant. Most likely because the head is not flat.
The second is still running fine and has had a couple of "boil overs" because of a failing radiator fan. But it's off the road now due to an accident.
The first two were 2003 models. The third is a 2005 model. It has virtually no liner clearance! At least none that I was capable of measuring! I have run the engine but not the car. This car was going to be a back up, but with the first engine causing trouble, I now need to get it on the road. It was virtually ready to go when I discovered that it was low on A/C refrigerant. In changing the A/C Schrader Valves I snapped one off in the pipe! To remove the pipe required disassembling part of the engine (inlet manifold) and the front R/H quarter of the car!
So I can not say (yet) if the liner protrusion is critical. I can only assume the liner protrusion is to ensure that the fire rings in the gasket crush down to form a tight seal. But having said that, iron block engines just have a flat deck and sleeved alloy blocks don't have any liner protrusion!? I saw a YouTube video and the guys used an MLS (multi layer steel) gasket out of a different variant of the TU block! I wonder how it went?
The cylinders are numbered from the gearbox end. But it only matters for the ignition timing. So if you get a "misfire in cylinder 1" you'll know where to go. But mechanically, it makes no difference.
The piston rings seem to be pretty good in these engines as even the 200K engine burns very little oil. About 1L per 10000Km. And I think that most of that is from the PCV system anyway. So any loss of compression, I have found, is from crud building up on the exhaust valve seat. All of the cars (and therefor engines) I have done the cylinder heads and gaskets on were previously operated by other people. Yes, the cars are second hand. So I have not pulled the head off an engine that I have operated (yet).
I only use a high quality (synthetic) oil. It's not really "synthetic" but the oil manufactures are allowed to get away with saying that. But it has made a MASSIVE difference to the performance of the first engine that I did. The first engine was a dog when I got it up and running. It had very poor performance. I would assume that the piston rings were caked in carbon. The exhaust valve seats and faces were pitted, But I didn't do anything about that. I did not do a compression test at the time. But over about 30-50000Km the engine gained at least 25% more power! I did absolutely nothing to the engine. I use 95RON petrol, and upper cylinder lube in the fuel (from time to time). Change the oil every 10000KM. I can only put the increase in performance to the oil cleaning out the ring grooves of the pistons. Now don't get me wrong, the over all performance of the engine is...OK (that's the nicest I can say). But compared to when I first got it up and running, it's much better now.
So I recommend not skimping on the oil and change it every 10000KM. I even used LEXIA to change the oil counter to 10000KM.
Hmm both cylinder head thickness under spec? I never checked the head thickness of any of the heads. I left that to the machine shop. But they didn't mention anything. The second engine that I did was the first head that I took to the machine shop. The guy immediately put his straight edge into the camshaft tunnel and said the head is warped! But they heat treated the head and got it straight. They put a lot of work into that head, I was very happy with their work. The third car was the second head that I took to the machine shop. The engine is around 80000Km and the head didn't need much work. They skimmed the head and I did a quick lap of the valves.
hungryhound69
Well It's all back together and running. The liners were indeed flush with the deck so I used a length of flat stone warped in 600 grade paper and sanded down the deck. Managed to get a 0.04mm protrusion but the deck was slightly out of spec having straightness not to 0.05mm but 0.06mm as measured with machinist 500mm straight edge and a set of filler gauges. I found a reference on one of the Australian boards dealing with TU3JP engines suggesting that as the deck gets old and often uneven to put a thin layer of hylomar m on the deck before placing a new gasket instead of following factory recommendation of clean surface. But my recondition head was straight to better than 0.02mm as that's the thinness filler gauge I have. So far so good all works. Pressurised the cooling system to 1.1 bar, left it for an hour no leaks. I put an OBD temperature gauge so to know if it's going to overheat.
What is now strange is that I got a P0485 error code (Cooling Fan Power/Ground-circuit Malfunction) and there was another code P098A (RH light open circuit) which disappeared once I turned on the headlights. I cleared the P0485 code and I think I get it when after using air-conditioning. But I ran the fans both high and low speed and thee was no issue detected. When air-con works the low speed fan kicks in. The fan resistor is new so I'm not sure what is the issue and whether it caused the overheating in the first place. Although I think the head gasket was already leaking before the overheating as I would get very slight over-pressure in the expansion tank after the car would cool down but I did test it for CO2 with negative results. But now it all works except for these intermittent codes.
ozvtr
- x 256
Keep an eye on the P0485. Failure of the radiator fans is one of the big contributors to boil over and head warpage.
If you get the P0485, stop the car ASAP and check that the fans operate. Turn on the A/C or disconnect the green coolant temp sensor. The fan(s) should come on.
hungryhound69
The slow fan comes on immediately if a/c is on and I can activate both slow and fast fan speeds with the OBD. The fan is good and the resistor is new. Not sure if it's related or just a coincidence that I got a RH lights was open circuit. The connector wasn't fully locked so I'll see if either codes come back. Not sure how they could be related even if the connector wasn't in full contact.
Just had that again with the RH side lamp open circuit. Seems the 2 codes come together even though the RH side lamp (ie parking lamp) and fan are working fine. So unscrewed the right side grounding point, it looked fine, cleaned it with sand paper and acetone and screwed it back. There is another one under the BSM on the left but it's difficult to get to. So I don't get why these codes come up.
Ok I figured out the cause of P0485. When using the a/c sometimes while the low speed says active it shows 0% fan instead of 50% but the fan is turning. I wonder whether it's the control module or the harness. This happens around 90C but not straight away so so something needs to heat up
ozvtr
- x 256
I'm not sure any of this is related to the P0485.hungryhound69 wrote: 04 Nov 2026, 07:40
Don't forget, the radiator fan is run by the engine ECU. BUT the engine ECU monitors both the engine temp AND the A/C high pressure line. The fan won't come on just because you have selected the A/C on. The high-pressure line in the A/C must get ABOVE a certain pressure (can't remember what) before the engine ECU will turn on the fan. So if you have a cold day, and you use the A/C (say, to defog the windscreen) the fan might not come on at all! The engine ECU will also turn the radiator fan on when the coolant temp gets above 98 (or so, again not sure). So, if either of these conditions happen the engine ECU will run the fan up.
So, you are saying that the engine ECU reports the fan active but 0%? Are you monitoring the fan speed from the engine ECU in LEXIA?
