Grand C4 Spacetourer service schedule booklet required.
ygw
Hi All,
On taking delivery of my pre-owned 2019 model/Jan 2020 registered Grand C4 Spacetourer last month, it came without a servicing schedule booklet which would have listed servicing periods and recorded actual servicing jobs performed, validated with the dealer's stamp. So now I am unable to determine at what time intervals or miles future servicing will become due, and what should be done at the time.
I asked a local Peugeot-Citroen dealer if I could buy a servicing booklet, but was told they are not used any more as servicing is recorded on Citroen's online system. However, up until shortly after the date of my car, those servicing booklets were in use.
Please can anyone tell me if it's possible to buy a servicing schedule booklet, and if so, where from?
Kind Regards
ygw
Kind Regards
ygw
- x 1431
Re: Grand C4 Spacetourer service schedule booklet required.
If you post up the VIN (it will auto hide), we can look it up.
ygw
Thank you Richard, the cars's VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Gordon
Gordon
ygw
Sorry, I didn't know that spaces in the alpha-numeric string should be omitted.
Here's the corrected VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Gordon
Gordon
- x 1431
See below. It's very important on these to stick to the oil change interval, and to use only the specified oil because of the 'wet' cambelt.
ygw
Thank you very much again for all your help and advice Richard. I'm now much better informed about my Spacetourer! I'll now print off the schedule and keep it with my other servicing records.
Kind Regards
Gordon
Kind Regards
Gordon
Jozsef63
Dear Richard,
Could you, please, help me in the same matter? Please read my VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Thank you in advance:
Jozsef
Jozsef
- x 6955
@Jozsef63:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Jozsef63
Dear Marc,
The donation is complete.
Thank you,
Jozsef
Thank you,
Jozsef
- x 6955
Hi Jozsef, thank you for your Forum donation.
Should you require any official part numbers & prices or parts diagrams for your PSA vehicle (s), please request these in the official parts thread Here, for the duration of your upgraded membership.
Here's your Servicing Schedule that shows when most things need doing along with the recommended engine oil and specification below:
Build Sheet
Build Sheet
| Vehicle Characteristics | |
| Vehicle Family | C4 PICASSO / C4 SPACETOURER (B78) |
| AS/RP N° | 16526 FV 2 0244 |
| Warranty Start Date | 28/02/2022 |
| Engine Serial Number | 10 Q4EP 0068920 |
| OPB | 00NA |
| BER | e2*2007/46*0356*31 |
| P4A | 9836042499 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C4 PICASSO / C4 SPACETOURER (B78) |
| SILHOUETTE | ESTATE - LEISURE |
| TRIM LEVEL | UPPER LOW |
| ENGINE | DV5RC/UE63 1.5 L DIESEL |
| TRANSMISSION | STT TYPE 8-SPEED AUTOMATIC GEARBOX |
| PAINT TYPE | METALLIC LACQUER |
| BODY COLOUR | EVL - PLATINUM GREY PAINT |
| INTERIOR TRIM TYPE | FINN FABRIC + TEP "V3" |
| UPHOLSTERY COLOUR | "FR" |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | DV TYPE ENGINE |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
| SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
| CATALYTIC CONVERTER | CATALYTIC CONVERTER BELOW 50PPM |
| FUEL TANK | FUEL TANK WITH LOCATING TAB |
| COOLING MOTOR | RADIATOR EP28 28DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" SELF-DIAGNOSIS |
| DEVICE (ANTIPOLLUTION) | EXHAUST GAS RECYCING "EGR" + EXCHANGER |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITH STOP AND START STARTER |
| Gearbox Transmission | |
| WHEEL STYLE | 17-INCH SHAMAL ALUMINIUM WHEEL 7 J17 CH 5-50 |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 17 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 205/55 R17 95V REINFORCED TYRE |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION |
| GEARBOX TYPE | ATN8 TYPE GEARBOX |
| Suspension-Steering-Brakes | |
| REAR ANTI-ROLL BAR | STIFFNESS 30000 NM/RAD |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 23 HOLLOW |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
| SUSPENSION | LOWERED SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | BOSCH 9.3 ESP |
| STEERING (OPERATION) | LOW POWER DOUBLE PINION ELECTRIC POWER STEERING |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | FR ROOF+GPS+DIG+INTEGRATED+GSM |
| FINISHER (SELF-ADHESIVE) | GLOSS BLACK REAR SURROUND TRIM |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| INDICATORS | WITHOUT SIGNALING LIGHTS |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| DRAUGHT EXCLUSION | FR AND RR DOOR AERODYNAMIC SEALING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN |
| WINDSCREEN WIPER | 2 SPEED INTERMITTENT+AUTOMATIC CADENCING |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | DOUBLE PILOTED AIR INLET CLOSER |
| ROOF GLASS | WITH ROOF WINDOW |
| BUMPER | BODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | MOUNTING WITH ROOF BARS |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| PANORAMIC VISUAL AID | WITHOUT PANORAMIC VISUAL AID |
| SPARE WHEEL | SPACE-SAVING SPARE WHEEL |
| EXTERIOR ACCESSORIES | BODY-COLOURED EXTERIOR HANDLE |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| WINDOW (TYPE) | LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS + BOOT + HANDS FREE STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| SUPPLEMENTARY SEAT | 2 PLACES SUPPLEMENT SEPAR SEATS |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| LUGGAGE COVER | LUGGAGE COVER + WINDSTOP |
| FRONT SEATBELT | PYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM |
| CLIMATE (AMBIENT TEMP) | COLD COUNTRIES |
| AIR CONDITIONING | WITH HEATER MATRIX |
| SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
| GEAR SELECTOR | GEAR CONTROL AT THE STEERING WHEEL |
| CONSOLE | WITH REMOVABLE CONSOLE |
| DRIVING POSITION | LEFT-HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| AIR EXTRACTOR | WITHOUT AIR EXTRACTOR |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | WITH GLOVEBOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | AUTO BOOT LIGHT OR LOAD VOL SWITCH |
| DASHBOARD EQUIPMENT | UPPER PART PEARLESCENT ARDOISE GREY |
| INT. TRIM AND EQUIPMENT VARIATION | CLOTH INTERIOR EQUIPMENT TRIM |
| MISC. INT. LAMPS | LIGHTING BY LEDS |
| WORK TABLE | WITH WORK TABLE |
| LOAD SPACE TRIM | FOAM BOOT MAT + SOUNDPROOFING |
| UNDERSEAT STORAGE | 2 UNDER SEAT STORAGE DRAWERS |
| INSTRUMENT PANEL (CHARACTERISTICS) | DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS |
| DOOR TRIM | DECOR GLOSS VARNISH |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS |
| ADDITIONAL BLOWER | WITH ADDITIONAL PULSE |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT ADJUSTMENT PASSENGER SPACER |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| DRIVER SEAT ADJUSTMENT | FR DRIVER SEAT CUSHION ADJUSTMENT RECLINING SEAT BACK |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER TILTING BACK |
| FRONT PASSENGER SEAT FOLDING | W/O FOLDING PASS FRONT SEATING |
| FRONT SEAT ARMREST | DRIVER ANT PASSENGER FRONT ARMREST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| STOWAGE BIN | FLAPS IN FLOOR |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
| HEADLAMP BULBS | DISCHARGE BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | PREVENTION+CORRECTION OF LATERAL TRAJECTORY |
| DISPLAY | DGT TOUCHSCREEN+12" DFT DISPLAY |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING |
| ELECTRIC WINDOW (OPERATION) | DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| COURTESY LAMP | CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITH WIFI |
| RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | ADAPTIVE CRUISE CONTROL AND SPEED LIMITER |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | NET SEAT BACK STORAGE POCKET |
| CARPET COVER | CARPET MAT 1 |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK |
| LATERAL BLINDS | SIDE BLINDS |
| FLOOR MAT | FR + RR MATS |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | SIMPLE + AUTOMATIC CENTRAL LOCKING |
| STEERING WHEEL | LEATHER STEER WHEEL 4 BRANCHS |
| SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| REAR VIDEO SCREEN | WITHOUT REAR VIDEO SCREEN |
| CHILD OBSERVATION INTERIOR MIRROR | INTERIOR CHILD MONITORING MIRROR |
| AUDIO PACK AUXILIARY SOCKET | 1 USB SOCKET |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
| Electrical | |
| ALTERNATOR | ALTERNATOR CLASS 18 HEA |
| BATTERY | L3 760 70AH EFBC 760 BATTERY BECOMES EFBC |
| STARTER MOTOR | STOP AND START BY STARTER |
| SPECIAL LIGHTING | FRONT DAY RUNNING LIGHT (DRL) |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| MULTIPLEXING | MODIFIED ECONOMY ELECTRICAL ARCHITECTURE |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19,3DM2 THICKNESS 12 |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| RADIO HEADPHONE SOCKET | DOUBLE ACCESSORY SOCKET |
| TRAFFIC SIDE | DRIVING ON THE RIGHT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
Jozsef63
Hello Marc,
Thank you very much. How can I check if this car has a valid guarantee or its service history.
Thank you,
Jozsef
Thank you,
Jozsef
- x 6955
Not sure I understand what you mean by 'guarantee', but assuming you may mean vehicle warranty - this is listed in the build sheet above, near the top (Warranty start date: 28/02/2022).
You will have to ask your dealer about any Citroen service history, they should have a record of this.
Jozsef63
Thank you, Marc. Yes, you are right, I meant "warranty" and sorry for this mistake. Since the dealer (not an official Citroen dealer, but a used car dealer) could not tell anything about the service history and the warranty period, I tried to turn to you with this request. This car was imported as a used car from France, I thought there is a digital service history I can check and I may obtain some information about the European warranty.
- x 6955
As far as European warranties go I believe they are slightly different from the UK. Here we have 3 years in total, 2 years from Citroen and the third year from the dealership.
If I'm not mistaken in Europe it is a total of 2 years. If this is the case, then it would of expired on 27/02/2024.
As I mentioned there's no digital service history we can see as that's confidential, so you'd have to get that from the dealership network.
It should of had 2 services by now as it is always annual servicing if under the 30k mileage.
citroenspacetourer
Hi All,
On taking delivery of my pre-owned 2023 model Spacetourer last month, it came without a servicing schedule booklet which would have listed servicing periods. So now I am unable to determine at what time intervals or kms future servicing will become due, and what should be done at the time. This is the VIN VF7**************[VIN obfuscated, can be read by forum staff]
Can someone please share the service schedule booklet and the specifications of the fluids to use?
Kind Regards
Bharat
Kind Regards
Bharat
