x 6961
Parts Service Announcement - 21st March 2025
Please note that there is a temporary disruption to our 'Parts Service', so we will be unable to provide any official parts for members at the present time. Please refer to the Post HERE for further info
x 6961
Re: Important Information concerning access to PSA parts data
The original part number for the screen fitted was 6563W0 (that's a zero at the end), costing £246.36 new; but has since been replaced with a newer part: 6564FA, costing £288.19. Item (1) below:
Prices from Peugeot correct as of today inclusive of VAT.
colinsunderland
x 3
Unread post by colinsunderland »
GiveMeABreak wrote: 15 May 2021, 23:13 No worries.
Hi Marc
Any chance you could get the part numbers for these please
Top drivers side engine mount
front wheel bearing
thanks very much
x 6961
Ok
Wheel Hub Bearing
if Item (4) which is (B + (14)), which is the Front Hub Bearing, then part 1606623580 (£118.51)
Cheaper PSA alternative Part No: 1623948880 @ £41.60
Engine Mount
Item (4) part no: 180944 @ £51.02
If anything else, let me know Colin.
colinsunderland
x 3
GiveMeABreak wrote: 14 Jun 2021, 18:43 Ok
Wheel Hub Bearing
Engine Mount
Thanks for that Marc
Hit a bit of a snag, when I was screwing bolt 73 in, the nut thing underneath came loose. I can't possibly get it on as can't get my fingers into where it needs to go. It's actually gone onto the bolt at a slight angle and although I can probably get it off, I know its going to drop.
Is there a part number for the exact nut the bolt screws into, or can I use any nut and bolt (similar size obviously)? Thanks very much
Zoolog
Unread post by Zoolog »
Hi Marc , It's not a part request per se and i might be in the wrong forum here, but i believe the OGRA number is accessible through the Citroen parts website so I'll ask here. Can someone please help me out with the OGRA (RP) number for my 99 Xantia? its not visible on the A pillar or under the paint code on drivers side bulkhead? The VIN is VF7**************[VIN obfuscated, can be read by forum staff].
x 6961
Sure, the RPO or build date code is 08249 (10th June 1999).
508Allure
x 5
Unread post by 508Allure »
Hi Marc,
Would you be able to help with a part number for the A/C condenser on a 2012 DS4 2.0 HDI 163 Sport manual please?
Last 7 digits of the Vin:
Many thanks.
x 6961
I can, no problem, but please post the VIN in full - our software will mask it automatically once you have submitted the post. You have only included 7 and we need the full VIN or the last 8.
508Allure
x 5
Apologies.
Full VIN: VF7**************[VIN obfuscated, can be read by forum staff]
x 6961
No worries, here you go - item (1) for your vehicle in the diagram.
You have a choice:
Part: 6455HJ for an original OEM £435.66 (these are the maintenance-free versions)
or Peugeot do an alternative cheaper one, part: 1610161980 for £142.56
All from Peugeot, prices correct as of this post and include VAT.
508Allure
x 5
Hi Marc,
Any chance of the part number for the quick release battery terminal on a 2014 508 please?
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks.
x 6961
No worries, can you identify the item from this:
508Allure
x 5
I'm guessing it's No.1.
Basically the quick release terminal on the battery positive post keeps slipping off as the quick release mechanism no longer seems to be tightening around the pole.
I was hoping the mechanism was separate to the cable but it looks like it's integral.
x 6961
Ok so that is part 6598JW and is a mere £165.67 inc. VAT from Peugeot. :shock:
