Grand C4 Spacetourer service schedule booklet required.
ygw
Unread post by ygw »
Hi All,
On taking delivery of my pre-owned 2019 model/Jan 2020 registered Grand C4 Spacetourer last month, it came without a servicing schedule booklet which would have listed servicing periods and recorded actual servicing jobs performed, validated with the dealer's stamp. So now I am unable to determine at what time intervals or miles future servicing will become due, and what should be done at the time.
I asked a local Peugeot-Citroen dealer if I could buy a servicing booklet, but was told they are not used any more as servicing is recorded on Citroen's online system. However, up until shortly after the date of my car, those servicing booklets were in use.
Please can anyone tell me if it's possible to buy a servicing schedule booklet, and if so, where from?
Kind Regards
ygw
x 1485
Re: Grand C4 Spacetourer service schedule booklet required.
If you post up the VIN (it will auto hide), we can look it up.
ygw
Thank you Richard, the cars's VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Gordon
ygw
Sorry, I didn't know that spaces in the alpha-numeric string should be omitted.
Here's the corrected VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Gordon
x 1485
See below. It's very important on these to stick to the oil change interval, and to use only the specified oil because of the 'wet' cambelt.
ygw
Thank you very much again for all your help and advice Richard. I'm now much better informed about my Spacetourer! I'll now print off the schedule and keep it with my other servicing records.
Kind Regards
Gordon
Jozsef63
Unread post by Jozsef63 »
Dear Richard,
Could you, please, help me in the same matter? Please read my VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Thank you in advance:
Jozsef
x 6956
@Jozsef63:
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Jozsef63
Dear Marc,
The donation is complete.
Thank you,
Jozsef
x 6956
Hi Jozsef, thank you for your Forum donation.
Should you require any official part numbers & prices or parts diagrams for your PSA vehicle (s), please request these in the official parts thread Here, for the duration of your upgraded membership. :wink:
Here's your Servicing Schedule that shows when most things need doing along with the recommended engine oil and specification below:
Build Sheet
Vehicle Characteristics
Vehicle FamilyC4 PICASSO / C4 SPACETOURER (B78)
AS/RP N°16526 FV 2 0244
Warranty Start Date28/02/2022
Engine Serial Number10 Q4EP 0068920
OPB00NA
BERe2*2007/46*0356*31
P4A9836042499
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 PICASSO / C4 SPACETOURER (B78)
SILHOUETTEESTATE - LEISURE
TRIM LEVELUPPER LOW
ENGINEDV5RC/UE63 1.5 L DIESEL
TRANSMISSIONSTT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPEMETALLIC LACQUER
BODY COLOUREVL - PLATINUM GREY PAINT
INTERIOR TRIM TYPEFINN FABRIC + TEP "V3"
UPHOLSTERY COLOUR"FR"
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)DV TYPE ENGINE
TRIM LEVELUPPER LOW
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.3 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
CATALYTIC CONVERTERCATALYTIC CONVERTER BELOW 50PPM
FUEL TANKFUEL TANK WITH LOCATING TAB
COOLING MOTORRADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION)EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
WHEEL STYLE17-INCH SHAMAL ALUMINIUM WHEEL 7 J17 CH 5-50
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE17 INCH TYRE FITMENT
TYRE (SIZE, TYPE)205/55 R17 95V REINFORCED TYRE
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPEATN8 TYPE GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BARSTIFFNESS 30000 NM/RAD
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR DIAMETER 23 HOLLOW
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONLOWERED SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTBOSCH 9.3 ESP
STEERING (OPERATION)LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
AERIALFR ROOF+GPS+DIG+INTEGRATED+GSM
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
INDICATORSWITHOUT SIGNALING LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
DRAUGHT EXCLUSIONFR AND RR DOOR AERODYNAMIC SEALING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN
WINDSCREEN WIPER2 SPEED INTERMITTENT+AUTOMATIC CADENCING
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKDOUBLE PILOTED AIR INLET CLOSER
ROOF GLASSWITH ROOF WINDOW
BUMPERBODY COL FR BUMPER+BLACK CAPPING CHR BEAD/BODY COL RR BUMPER
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFRONT FOG LIGHTS
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
SPARE WHEELSPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIESBODY-COLOURED EXTERIOR HANDLE
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE)LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
HANDS FREE ACCESS AND STARTINGFRONT ACCESS + BOOT + HANDS FREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
SUPPLEMENTARY SEAT2 PLACES SUPPLEMENT SEPAR SEATS
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
LUGGAGE COVERLUGGAGE COVER + WINDSTOP
FRONT SEATBELTPYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
AIR CONDITIONINGWITH HEATER MATRIX
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GEAR SELECTORGEAR CONTROL AT THE STEERING WHEEL
CONSOLEWITH REMOVABLE CONSOLE
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
AIR EXTRACTORWITHOUT AIR EXTRACTOR
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGWITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTINGAUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENTUPPER PART PEARLESCENT ARDOISE GREY
INT. TRIM AND EQUIPMENT VARIATIONCLOTH INTERIOR EQUIPMENT TRIM
MISC. INT. LAMPSLIGHTING BY LEDS
WORK TABLEWITH WORK TABLE
LOAD SPACE TRIMFOAM BOOT MAT + SOUNDPROOFING
UNDERSEAT STORAGE2 UNDER SEAT STORAGE DRAWERS
INSTRUMENT PANEL (CHARACTERISTICS)DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIMDECOR GLOSS VARNISH
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
ADDITIONAL BLOWERWITH ADDITIONAL PULSE
PASSENGER COMPARTMENT SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENTFR DRIVER SEAT CUSHION ADJUSTMENT RECLINING SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER TILTING BACK
FRONT PASSENGER SEAT FOLDINGW/O FOLDING PASS FRONT SEATING
FRONT SEAT ARMRESTDRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISCWITHOUT COMPACT DISC
STOWAGE BINFLAPS IN FLOOR
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSDISCHARGE BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERPREVENTION+CORRECTION OF LATERAL TRAJECTORY
DISPLAYDGT TOUCHSCREEN+12" DFT DISPLAY
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
ELECTRIC WINDOW (OPERATION)DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
COURTESY LAMPCONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
WIFIWITH WIFI
RADIO RECEIVERDIGITAL CONNECTED NAVIGATION
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLADAPTIVE CRUISE CONTROL AND SPEED LIMITER
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)NET SEAT BACK STORAGE POCKET
CARPET COVERCARPET MAT 1
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIOMONO RADIO TUNER
OBSTACLE DETECTION SYSTEMFR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK
LATERAL BLINDSSIDE BLINDS
FLOOR MATFR + RR MATS
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLSIMPLE + AUTOMATIC CENTRAL LOCKING
STEERING WHEELLEATHER STEER WHEEL 4 BRANCHS
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREENWITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRRORINTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET1 USB SOCKET
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATORALTERNATOR CLASS 18 HEA
HORNSHORNS-HARMONY
BATTERYL3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTORSTOP AND START BY STARTER
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
MULTIPLEXINGMODIFIED ECONOMY ELECTRICAL ARCHITECTURE
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
CONDENSER (SPECIFICATIONS)CONDENSER 19,3DM2 THICKNESS 12
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
Jozsef63
Hello Marc,
Thank you very much. How can I check if this car has a valid guarantee or its service history.
Thank you,
Jozsef
x 6956
Not sure I understand what you mean by 'guarantee', but assuming you may mean vehicle warranty - this is listed in the build sheet above, near the top (Warranty start date: 28/02/2022).
You will have to ask your dealer about any Citroen service history, they should have a record of this.
Jozsef63
Thank you, Marc. Yes, you are right, I meant "warranty" and sorry for this mistake. Since the dealer (not an official Citroen dealer, but a used car dealer) could not tell anything about the service history and the warranty period, I tried to turn to you with this request. This car was imported as a used car from France, I thought there is a digital service history I can check and I may obtain some information about the European warranty.
x 6956
As far as European warranties go I believe they are slightly different from the UK. Here we have 3 years in total, 2 years from Citroen and the third year from the dealership.
If I'm not mistaken in Europe it is a total of 2 years. If this is the case, then it would of expired on 27/02/2024.
As I mentioned there's no digital service history we can see as that's confidential, so you'd have to get that from the dealership network.
It should of had 2 services by now as it is always annual servicing if under the 30k mileage.
citroenspacetourer
Unread post by citroenspacetourer »
Hi All,
On taking delivery of my pre-owned 2023 model Spacetourer last month, it came without a servicing schedule booklet which would have listed servicing periods. So now I am unable to determine at what time intervals or kms future servicing will become due, and what should be done at the time. This is the VIN VF7**************[VIN obfuscated, can be read by forum staff]
Can someone please share the service schedule booklet and the specifications of the fluids to use?
Kind Regards
Bharat
