Hi,
One of the coolant hoses connecting the oil cooler to the radiator ruptured on my Xantia 2 1.9TD. As per Citroen's Servicebox, the OEM part is 1307LN. This hose is nowhere to be found, so I checked the same hose for a Xantia 1 1.9TD with a/c and there the OEM number is 1307AK, and this hose is readily available.
Does anyone know if these parts are interchangeable?
Xantia 2 1.9TD, radiator-to-cooler hose question.
Xantia Estate MK.2 1.9 TD, 1999
- white exec
Re: Xantia 2 1.9TD, radiator-to-cooler hose question.
I have had a quick look at Parts, and the use of those two hoses is not straightforward.
They were used on both Xan I and Xan II, with/without AC, manual/auto boxes - so quite a mixture.
If you can post your VIN (which will appear masked), we can find out which hoses will fit yours, and look at availability.
Will have to ask you for a donation to the forum for this, which will cover you for other parts queries for the whole of this year and next.
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
Hi,
You guys helped me a lot with this forum, so I'd be glad to help. I made a donation, to whom should I send the confirmation for it?
The VIN number of the car is: VF7**************[VIN obfuscated, can be read by forum staff]
Thanks!
Thanks!
- white exec
The donation has gone through ok, thank you, and you're now flagged as 'Donor 2021'.
Will look out the hose info.
- white exec
Both 1307LN and 1307AK are NFP at Citroen, but do look pretty much equivalent to each other.
Both fitted to Xantia XUD9TE with A/C... Your car's RP = 7889
1307 AK was fitted to cars RP 6356-7482
1307 GZ was fitted from RP 7123 onwards, but also NFP, and not showing up on the searches I did.
1307 AK showing in stock at Mister Auto UK, as a SASIC SWH0288 £23.50
It's also showing in stock on Autodoc - a couple of brand choices.
All seem to connect oil cooler to radiator bottom right.
Not sure whether Mister Auto UK is now fully active again; you'll need to try it.
Item showing as ok on their .es site, and most stock is held in France anyway.
Hope helpful.
Hope helpful.
Thanks a lot Chris, much appreciated!
I'd also need to change the hose clamps for the said hose, but I can't clearly make it out what the OEM numbers are on those. Could you help me out on those? I hope at least they are always the same.
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
If it's the Jubilee hose clamps item (80), these are part: 6981K4 (DIAM 23-35 LARG 9) and cost £1.45 each from Citroen.
Click or Tap Image to Zoom
These should do it. Thanks, Marc!
The mechanic (btw not a Citroen one, so doesn't have access to Servicebox), said that what is important is the coolant radiator and oil cooler on my car to be the same as these on a late model Xantia 1 1.9TD, equipped with the 1307AK hose, variations on the form of the hose don't matter in this case as long as the connectors are of the same diameter. We do not want to be stuck with a hose that is not useful to us, he said.
I think they should be the same, but could we check these to be sure? Thanks!
PS: 2 years ago I changed the coolant radiator and oil cooler. The oil cooler is the exact same as the original one, but the coolant radiator (and top and bottom main hoses) I have replaced with these for a Xantia 1 1.9TD, so should be an even greater advantage here.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Part: 1301 GL Radiator was also fitted to:
TURBO INJECTION XU10J2TE
TURBO DIESEL XUD11BTE
DIESEL TURBO XUD9SD
TURBO DIESEL XUD9TE AND BVM (Your Car)
Part: 1103 A2 Oil Cooler (EP 66,3) was fitted to:
TURBO DIESEL XUD9TE (Your Car)
TURBO DIESEL XUD11BTE AND WITHOUT AIR CONDITIONING
TURBO DIESEL XUD11BTE AND WITH AIR CONDITIONING
The other models have a different measurement from the EP 66.3 (56.6 & 47.6)
DIESEL TURBO XUD9SD
Thanks, Marc! With these numbers at hand I poked through the forum and saw what some of the other coolers might be:
viewtopic.php?t=23995
With what you and Chris provided, I am fairly confident it will fit.
