how many differant oil coolers are there between all the XUD engines,
one of my customers has got hold of a second hand oil as his has aquired some damage (wasn't me), the replacement is thinner so in turn the original fixing is to long
regards malcolm
ps.
this car is an Nreg 1.9TD
oil coolers
AndersDK
From the BX, Xan & XM engines :
1103 A9 EP=56,6 - INDTIL OPR 05579
1103 C9 EP=47,6 - SIDEN OPR 05472
1103 A2 EP 66,3 - DIESEL TURBO XUD9TE
1103 G2 EP 56,6 - DIESEL TURBO XUD9SD INDTIL OPR 08007
1103 N1 EP 69,2 VALEO THERMIQUE - - DIESEL TURBO DW10 SIDEN OPR 08421
2L turbo - angled studs
1103 F7 - INJECTION TURBO XU10J2TE
And possibly more variant on later engine types
The V6 ones (XM, Xantia) are however quite different because of their welded on preshaped long steel pipes for the coolant.
Besides you got a range of similar coolers for autoboxes.
I suspect the EP figure is the coolant volume (in mL) that the cooler will hold.
Anders (DK) - '90 BX16Image
- x 94
