Peugeot T9 clunking noise
Narl
x 4
Unread post by Narl »
2015 Peugeot T9 has a clunking noise from P/S/F area.
Only seems to happen from a standing start like waiting at lights as soon as you come off the clutch on to the accelerator.
The noise doesn’t appear to happen when going over speed bumps etc, you can intermittently hear the noise when the car is slowing down in gear.
I have had the car checked with a local mechanic, the only thing he could see is the drive shaft going into the box has a little more play than normal also noticed there is a slight bit of movement on the gearbox side of things.
If I am to post my VIN would it be at all possible to get part number for the fore mentioned above?
Thanks.
x 6957
Re: Peugeot T9 clunking noise
Also be aware of the bushings in the wishbone. These can not always easily be moved when checking under the car, but with the car on the road and all the weight from a lunge forward or from braking, it is enough to move the bushing back and forward to make a clunking noise.
We can help you with live PSA parts data and Parts diagrams, but require a min £10 donation, as we are also charged by PSA now for this info. However this will cover you for up to 2 years of parts requests, so is excellent value. Details below:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
Narl
x 4
Hi. Sorry for the late reply a few months later haha.
Yeah it was on the lift today wish bones etc are all on the mechanic showed me the play in the drive shaft it does appear to have excessive play.
I have got a quote for the drive shaft it worked out at over £340.00. I was hoping to get the part numbers but they didn’t reveal those at all.
In addition the thrust or clutch release bearing is starting to go again which will need replaced so I’d be looking a complete clutch kit including slave cylinder.
Vin / Chassis number is VF3**************[VIN obfuscated, can be read by forum staff]
x 6957
Ok, thanks for that - leave it with me and I'll pop something up for your shortly.
Ok so Driveshafts:
Left (1)
9677914880 (Brand New) £398.33
1610205880 (Exchange) £231.95
Right (2)
9670725580 (Brand New) £398.33
1610205380 (Exchange) £231.95
The above prices are direct from any Peugeot Dealer and include UK VAT.
There is a deposit of £66.96 each on these, refundable on return of the old part.
Any other parts on the diagram you need numbers for, let me know. I'll sort the clutch parts in a new post below.
x 6957
Clutch Kit (1) (Includes 'A' & 'B')
9831386880 (Brand New) £402.10
1612865280 (Exchange) £195.11
Slave Cylinder / Thrust Bearing (3)
9677933380 (Brand New) £161.64
1666659080 (Peugeot Cheaper Alternative) £56.96
Again, VAT inclusive but a £44.64 refundable deposit on the Clutch Kits not included in above prices.
You have not mentioned the Dual Mass Flywheel, which is always recommended to be done if changing the clutch as it rarely outlasts a new clutch, so I've included the part numbers and prices for you just in case.
Dual Mass Flywheel (10)
9806761080 (Brand New) £612.61
1666823480 (Exchange) £342.61
£100.44 Refundable Deposit on these in addition to the above.
