207 problems
207 problems
just became owner of a peugeot 207 1.6vvt and im regretting already its come up with open curcuit fault bank 2 on diag and runs crap ,ive replaced both vvt solenoids and theres power to them ,if i disconnect one solenoid it runs ok anyone know where i can download a free wiring diagram for this or has had the same issues thanks
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5711
Re: 207 problems
Post your VIN up if you want a diagram and be a little more specific - is it the engine management system you want?
Re: 207 problems
5fw 207 1.6 vvt automatic 2008 . start car ,runs rough keeps cutting out ,disconnect one vvt solenoid car starts and will run all day.checked so far .timing ,power to both vvt solenoids good ,any help please FORGOT TO MENSION BOTH VVT SOLENOIDS REPLACED WITH GENUINE
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 207 problems
Please read my last post - I need a VIN if you want a diagram.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3006
Re: 207 problems
The VIN will be automatically obscured so that only Forum staff can read it. The VIN can normally be found on the V5 logbook, and in a small clear patch on the lower left of the windscreen. The reason Marc needs the VIN is to make sure he gets the right information for YOUR 207. As they were made in various factories, and with differing components/configurations (including wiring looms) anything without said VIN would be just a guess.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Re: 207 problems
vin VF3**************[VIN obfuscated, can be read by forum staff]
Re: 207 problems
forgot to mension p code p0013.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 207 problems
This is the description of your fault. I'll put up a diagram within the next 10 minutes for you.
Fault code | P0013 |
After sales description of the fault code | Exhaust variable timing electrovalve control fault : Open circuit |
Description of the diagnostics | Detection of an open circuit on the exhaust camshaft dephaser electrovalve power stage (For more than 0,5 s) |
Conditions of activation of the diagnostics | The following conditions have to be met -Main wake-up: - Battery voltage between 9 and 17,9 V - Engine running and power relay jammed for 2 seconds - The output terminal has gone through the high and low statuses |
Conditions of disappearance of the fault | Check that there are no fault codes: P2091 - P2090 - P0013 (For 1 second) |
Down-grade modes if fault present |
Switching on of the warning lamp and/or warning message | Warning lamp MIL |
Main customer complaints likely |
Suspect areas | Exhaust camshaft dephaser control power stage |
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 207 problems
Here's the diagram for your 207 5 DOOR SALOON 1.6 VTi 16V 120 (EP6):
Hardware
1320: Engine ECU / Injector Supply
1107: variable valve position sensor
Wiring:
1452: sensor input VVT1
1453: vvt1 sensor output
1458: VVT sensor earth
1456: VVT sensor supply
1457: VVT sensor clock
1454: sensor input VVT2
1455: vvt2 sensor output
412: Oil pressure signal
Hardware
Wiring:
Re: 207 problems
thank you so much for your help
graham.
graham.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 207 problems
No worries, I hope this helps track the issue.
Re: 207 problems
yes but with out knowing wire colours or rest ofdiagram instructions im a bit snookered im not an auto electrician just an old guy who likes messing
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 833
Re: 207 problems
PSA wiring does not primarily use colours for identification. You will see numbers (often 4 digit) on the diagram, these same numbers are printed on the wires every few cm.
Marc, what are the component code numbers of the VVT solenoids?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 207 problems
1243: variable timing electrovalve 1
1268: variable timing electrovalve 2
Re: 207 problems
thats brilliant marc once again im in your debt ,now if i can find my glasses i can have a mess
thanks again graham
fingers crossed...
thanks again graham
fingers crossed...
