How to remove the interior rearview mirror on C4 B7?
Cutac
x 20
Unread post by Cutac »
Hello,
I'd like to install an aliexpress rearview mirror with a screen for a backup camera. To do so, I'd need to take my current mirror off so I can see what type of mount it's using, but I don't know how to remove the mirror and fear of breaking the windshield.
So, quite simply, how to remove the regular interior mirror on C4 B7?
P.S.
these are brackets offered by aliexpress seller
x 6957
Re: How to remove the interior rearview mirror on C4 B7?
Just a few to choose from then! Once you have removed it as shown, you should have a better idea of the type of fixing you need. :-D
It's recommended to use Battery disconnection procedure before removing the sensitive sensor:
BSI Rest / Battery Disconnect / Reconnect Procedure
Unclip: The 2 trim cowlings (1), (2) ( as "a") using trim tools.
Detach and remove: The 2 trim cowlings (1), (2).
Disconnect the connector ( as "b").
Unclip: The securing clip 3 ( as "c").
Detach:
  • The securing clip 3 (In the direction of the arrow )
  • The rain/sunlight bi-sensor (4)
Remove the rain/sunlight bi-sensor (4).
Caution: Protect the contact cushion of the rain/sunlight bi-sensor
with a transparent adhesive strip; Store the rain/sunlight bi-sensor in an envelope.
Disconnect the connector ( as "a").
Unclip: The interior mirror (1) (In the direction of the arrow - Anti-clockwise).
Remove: The interior mirror (1).
Cutac
x 20
Thanks for the tutorial!
But, I've tried pulling it off but it doesn't budge, and I'm afraid I'll break the windscreen. I'm going to go to the dealer and ask the tech there.
x 6957
Have you twisted it anti-clockwise first - it’s locked into place so needs twisting in the direction shown?
x 1940
The arrow shows twisting clockwise. Which is correct?
x 6957
It is very clear to me - 9 o'clock to 3 o'clock arrow head is to the right as is the description - anticlockwise - as you are facing the mirror
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
GiveMeABreak wrote: 21 Jul 2019, 18:31 It is very clear to me - 9 o'clock to 3 o'clock arrow head is to the right as is the description - anticlockwise - as you are facing the mirror
Have to agree with the above :)
x 1940
Have to still disagree. Rotating from 9-o'-clock to 3-o'-clock is very definitely clockwise! But, hey-ho.
x 6957
Not when it says anticlockwise
x 1940
But the diagram shows the arrow clockwise.
Detach: •The securing clip 3 (In the direction of the arrow )
What am I missing here?
x 6957
Your having a Specsavers moment. You’re looking at the wrong diagram!
We’re all talking about the last picture in the sequence....
x 1940
Ah, that was not all clear. I'll get my coat.
Cutac
x 20
Ohhh...
Thanks for that, I'm ashamed to admit, but I thought I was supposed to pull it/twist it downwards towards the rear of the car.
I'll try turning it tomorrow :mrgreen:
zane2g2
Unread post by zane2g2 »
hi ya,
Would anyone happen to have the removal illustration for the rest of the windscreen trim please.
In particular I'm looking for the 2nd mini mirror and interior light cluster above the winscreen.
Basically I have installed a Dashcam and want to hide the power cable in the trim :-)
Can't stand cable ties and seeing the wire exposed..... it just looks pants :-)
Cheers
Zane
x 6957
I just tucked my wiring along the roof headlining above the windscreen, and down inside the A pillar, then into the dashboard side covering and from there you have your earthing points and access to the fusebox for use with a piggy back fuse.
