09 C5 x7 2.0hdi Auto Driveshaft replacement
x 6946
Re: 09 C5 x7 2.0hdi Auto Driveshaft replacement
GiveMeABreak wrote: 11 Mar 2019, 21:58 I had a feeling that was coming 😃
Part no: 693684 lower ARB nut. (5)
Part no: 693665 (4)
Already dealt with parts (4) and (5) Richard :-D the Drop bar link - that is number (5)
The issue is with item number one of the pivot support..... That is part of the suspension strut.
The bit is (1) highlighted in Red
x 3565
Depending on where you look, the nuts are either special flanged nuts (genuine PSA), or standard nyloc with/without a washer. I have a feeling the genuine ones aren't standard thread, no idea of non-genuine ones though.
eBay - fair use
eBay - fair use
x 1496
GiveMeABreak wrote: 12 Mar 2019, 15:22
Part no: 693665 (4)
Which is the bit I posted - the bottom of the strut is held to the hub carrier by the top of the drop link (see the pics Bobbins posted with the long bar on the top end of the link), hence the nut (1) is shown on the ARB page.... :roll:
x 6946
Oh of course, I see it now, apologies Richard, that would explain why there is no separate part and the top of the drop link having a very long screw,
It must be the current topical events causing me to have a Top Hat moment!
x 1496
:-D
Jim66a
x 9
Unread post by Jim66a »
I changed my driveshafts over the weekend, The job went really well. My only issue was the passenger side arb drop link lower ball joint was just spinning and the hex was rounded off. I had replacement drop links so was able to get the mole grips in to hold it. The rest all behaved and came undone.
The job has resolved my knocking while steering was turned and vibration issue too. Drivers side inner uj was real stiff.
Thank you everyone for all your time, help and advice.
x 2361
Unread post by MattBLancs »
GiveMeABreak wrote: 11 Mar 2019, 18:09 Jim, Here's the guide on doing the Driveshaft Operation on your C5 X7 with AM6. ....
Right Hand Driveshaft
  • Undo the 2 screws (9) of the RH driveshaft bearing.
  • Move aside the circlip (10) in the direction of the arrow "a".
  • Release the RH driveshaft by pivoting the front half-axle upwards.
  • Remove the right-hand drive shaft.
(Hopefully editted that down correctly, not easy on the phone!)
Just diving in to this job (on my similar 2.2 ML6 equipped CT X7)
Note, a refinement to the above: The top fixing ( number 9 - says to "undo" ) of the driveshaft "circlip" doesn't need to be removed completely, only loosen enough to slide out the circlip which is slotted in this bolt position. This may pose a blessed relief given quite how poor access in this area seems to be!
Matt
Clunk84
New User
Unread post by Clunk84 »
Hi Guys how have I not found this forum sooner !! I’m looking to change my ns driveshaft on my 09 c5 x7 and I’m going to have to depressurise the manual way … could anyone inform me please how much old fluid I am likely to lose from the process so I can get some in advance and also do I have to do both axles or just the front …?
Thanks in Advance
Regards
Rob
x 6946
Hi Rob
You shouldn't loose too much fluid to be honest, but I'd hae at least a litre of LDS handy - just don't re-use any fluid recovered.
Each axle can be separately depressurised - see my post here:
viewtopic.php?p=602312#p602312
mikedrop
Unread post by mikedrop »
Great info on this page guys, thank you!
I'm about to tackle replacing driveshaft on drivers side (RHD) of my manual C5 2.0HDI 160. The guide makes sense. How critical is it to depressurise the axle? I've recently replaced the wheel bearing, bottom swivel bearing and rear wishbone bush without depressurising. I just need to know whether it's critical so I can order some LDS fluid :-D
Cheers
Mike
ETA - I've just read this post and assume it's for safety, rather than access. viewtopic.php?t=74271
x 6946
Mike, the reason why the circuit is depressurised is because officially, the operation is done with the vehicle being lifted off the ground where the wheels will be hanging freely, so this is to avoid the problems of potentially burst LDS tanks associated when the vehicle is lowered back to the ground (see this post for reference: viewtopic.php?t=62058). I suspect it make the job easier if the system is not under pressure on the front axle, as remember the suspension circuit is still active without the engine running, so it can still start height correction even with the engine switched off.
However if you are planning on doing the operation with the vehicle on the ground with just the front corner raised you may get away with it. I think I put a guide up here:
viewtopic.php?p=579003#p579003
mikedrop
GiveMeABreak wrote: 27 Dec 2023, 11:33 Mike, the reason why the circuit is depressurised is because officially, the operation is done with the vehicle being lifted off the ground where the wheels will be hanging freely, so this is to avoid the problems of potentially burst LDS tanks associated when the vehicle is lowered back to the ground (see this post for reference: viewtopic.php?t=62058). I suspect it make the job easier if the system is not under pressure on the front axle, as remember the suspension circuit is still active without the engine running, so it can still start height correction even with the engine switched off.
Thank you for that! Appreciate it! I'll get the parts ordered and report back :-D
mikedrop
Marc, any tips for releasing the drive shaft bearing? I've tried to pry it out and hammer it out and it's well and truly stuck.
x 6946
Nothing other than what's in the guide - they use that tool (5707-T)for extracting the ball joint.
mikedrop
GiveMeABreak wrote: 28 Dec 2023, 14:30 Nothing other than what's in the guide - they use that tool (5707-T)for extracting the ball joint.
Got the driveshaft out eventually with the use of a percussive persuasion device 8-[
Turns out the shaft was fine (luckily, as I'd been sent an Auto shaft and mine is a manual). Regreased and replaced the CV boot clips as a matter of cause and reassembled. Next up, passenger side wheel bearing.
