Hdi dv6 Citroen gp2008 electric wiring pdf
Ayyaad
Unread post by Ayyaad »
Plz can any technical engineer help me to find wiring diagram for all electric connection for Citroen grand Picasso diesel 2008 motor hdi dv6?
x 8119
Re: Hdi dv6 Citroen gp2008 electric wiring pdf
Which part of the system are you after? :)
Ayyaad
I need all wiring diagram through all motor area
Ayyaad
11263Fv
20478
EXYB
x 8119
These are the four diagrams contained in my backup system for your engine, based on the limited information available: :)
cpic1.pdf
(2.61 MiB) Downloaded 18 times
cpic2.pdf
(2.26 MiB) Downloaded 19 times
cpic3.pdf
(2.59 MiB) Downloaded 30 times
cpic4.pdf
(3.72 MiB) Downloaded 22 times
Ayyaad
many thanks
Ayyaad
OPR 11263
Hope to find complete pdf for 11263
Cooling circuit.....
x 8119
Ayyaad wrote: 02 Aug 2026, 16:34 OPR 11263
That is the second diagram I sent you. :) The RPO is for the correct year and only concerns the build year so it should be correct for yours. :)
x 8119
Just in case, here is the 11263 diagram :)
cooling 11263.pdf
Cooling for RPO 11263
(2.26 MiB) Downloaded 17 times
Ayyaad
Thanks v.much
coolant temperature sensor not clear in the diagram {mention only 12--}
Ayyaad
Dear Mr.Forum Admin
plz want help for complete wiring diagram for 11263
x 8119
Here are the other 3 diagrams for 11263 power unit. Ignor the typo in the injection filename, extra 6 included by accident, but it is the correct file. Now you have all I have. A donation to the forum would be most welcome via the donations button above. :)
112663 injection.pdf
11263 Injection
(3.72 MiB) Downloaded 16 times
11263 starting.pdf
11263 Starting
(2.59 MiB) Downloaded 22 times
11263 ignition.pdf
11263 Ignition
(2.61 MiB) Downloaded 19 times
Ayyaad
Thanks v.much
you help me too much
