Hdi dv6 Citroen gp2008 electric wiring pdf
Ayyaad
Unread post by Ayyaad »
Plz can any technical engineer help me to find wiring diagram for all electric connection for Citroen grand Picasso diesel 2008 motor hdi dv6?
x 7966
Re: Hdi dv6 Citroen gp2008 electric wiring pdf
Which part of the system are you after? :)
Ayyaad
I need all wiring diagram through all motor area
Ayyaad
11263Fv
20478
EXYB
x 7966
These are the four diagrams contained in my backup system for your engine, based on the limited information available: :)
cpic1.pdf
(2.61 MiB) Downloaded 7 times
cpic2.pdf
(2.26 MiB) Downloaded 9 times
cpic3.pdf
(2.59 MiB) Downloaded 13 times
cpic4.pdf
(3.72 MiB) Downloaded 7 times
Ayyaad
many thanks
Ayyaad
OPR 11263
Hope to find complete pdf for 11263
Cooling circuit.....
x 7966
Ayyaad wrote: 02 Aug 2026, 16:34 OPR 11263
That is the second diagram I sent you. :) The RPO is for the correct year and only concerns the build year so it should be correct for yours. :)
x 7966
Just in case, here is the 11263 diagram :)
cooling 11263.pdf
Cooling for RPO 11263
(2.26 MiB) Downloaded 7 times
Ayyaad
Thanks v.much
coolant temperature sensor not clear in the diagram {mention only 12--}
Ayyaad
Dear Mr.Forum Admin
plz want help for complete wiring diagram for 11263
x 7966
Here are the other 3 diagrams for 11263 power unit. Ignor the typo in the injection filename, extra 6 included by accident, but it is the correct file. Now you have all I have. A donation to the forum would be most welcome via the donations button above. :)
112663 injection.pdf
11263 Injection
11263 starting.pdf
11263 Starting
(2.59 MiB) Downloaded 7 times
11263 ignition.pdf
11263 Ignition
Ayyaad
Thanks v.much
you help me too much
