Lucas epic pump.
johncarden7
Lucas epic pump.
Unread post by johncarden7 »
Hi , pump packed up, got a 2nd hand one but cogwheel was removed. Anybody know how to refit in correct position? Theres a slot in the spindle but no woodruff key in the wheel! ( on either the old or new pump!) There are some dots stamped on one of the wheel spokes. Do i line them up with the slot on the spindle perhaps? HELP!
x 8123
Re: Lucas epic pump.
Picture or two would help you get some replies: :)
viewtopic.php?p=516529#p516529
x 1459
Unread post by xantia_v6 »
This epic topic may have some useful information.
viewtopic.php?t=45980
And this post viewtopic.php?p=440669#p440669
johncarden7
Still struggling with this! What if i manually crank the engine and note when fuel comes out of no.1 piston pipe to injector? Should that happen ay TDC for example? Any ideas anyone?
x 1459
The second link I gave above links to the factory procedure for pinning the pump and engine to TDC.
Once that is done, fit the belt and set the fine static timing by aligning the pump on the bracket.
