Help identify correct mirror
amazighman
Hi
I have a 5008 mk1 2.0 hdi with an intermittent power folding driver wing mirror , setting off for work and the mirror wont unfold , have to try few times using cockpit switch for it to work , sometimes it works fine.
Tried sourcing a second hand mirror assembly but there are few different ones and I cant determine which one , can someone with access to parts diagrams help?
I can provide the vin
Cheers
Cheers
- x 8084
Re: Help identify correct mirror
I have access to a parts diagram for 2011 but I need to know your body style and gearbox type as well as your RPO number on the tyre sticker on the door. It is not labelled RPO but is usually the first number under the top line on the sticker. I need that info to feed into the parts system to find the right part as I do not have access to the VIN based system.
amazighman
Thanks for your reply
amazighman
Hi.mickthemaverick wrote: 24 Mar 2026, 10:21 I have access to a parts diagram for 2011 but I need to know your body style and gearbox type as well as your RPO number on the tyre sticker on the door. It is not labelled RPO but is usually the first number under the top line on the sticker. I need that info to feed into the parts system to find the right part as I do not have access to the VIN based system.![]()
RPO 1249589
Body style MPV or SUV 7 seater
Gearbox Aisin 6 speed automatic ( not semi automatic)
- x 8084
Here you go:
amazighman
Wonderful stuff , I could not thank you enough
Thanks a lot.
amazighman
If you dont mind could you help identify the correct number for left side driveshaft? The short one?
Looked on Autodoc and there seems to be two different sizes
Many thanks
Many thanks
- x 8084
This may help:
amazighman
Thank you very much Indeed.
amazighman
Is it advisable to replace the driveshaft oil seal in the transmission?
- x 8084
Yes I would as it is cheap by comparison to stripping it all down again should it fail in the future. Plus if you are replacing the shaft then it makes sense to have a new seal to bed to it.
amazighman
Can I be cheeky , and sorry I have been a pain , whats the part number for the seal left side?mickthemaverick wrote: 31 Mar 2026, 16:28 Yes I would as it is cheap by comparison to stripping it all down again should it fail in the future. Plus if you are replacing the shaft then it makes sense to have a new seal to bed to it.![]()
Thanks a lot
- x 8084
That will have to wait as I cannot access my system at the moment, I will have a look when I can
amazighman
Cheers
- x 8084
