Help identify correct mirror
amazighman
Unread post by amazighman »
Hi
I have a 5008 mk1 2.0 hdi with an intermittent power folding driver wing mirror , setting off for work and the mirror wont unfold , have to try few times using cockpit switch for it to work , sometimes it works fine.
Tried sourcing a second hand mirror assembly but there are few different ones and I cant determine which one , can someone with access to parts diagrams help?
I can provide the vin
Cheers
x 8083
Re: Help identify correct mirror
I have access to a parts diagram for 2011 but I need to know your body style and gearbox type as well as your RPO number on the tyre sticker on the door. It is not labelled RPO but is usually the first number under the top line on the sticker. I need that info to feed into the parts system to find the right part as I do not have access to the VIN based system. :)
amazighman
Thanks for your reply
amazighman
mickthemaverick wrote: 24 Mar 2026, 10:21 I have access to a parts diagram for 2011 but I need to know your body style and gearbox type as well as your RPO number on the tyre sticker on the door. It is not labelled RPO but is usually the first number under the top line on the sticker. I need that info to feed into the parts system to find the right part as I do not have access to the VIN based system. :)
Hi.
RPO 1249589
Body style MPV or SUV 7 seater
Gearbox Aisin 6 speed automatic ( not semi automatic)
x 8083
Here you go:
5008 door mirror.pdf
Copied from ServiceBox backup
(139.25 KiB) Downloaded 65 times
amazighman
mickthemaverick wrote: 24 Mar 2026, 14:32 Here you go:
Wonderful stuff , I could not thank you enough 🙏
Thanks a lot.
amazighman
If you dont mind could you help identify the correct number for left side driveshaft? The short one?
Looked on Autodoc and there seems to be two different sizes
Many thanks
x 8083
This may help:
5008 Driveshafts.pdf
Copied from Service Box
(147.73 KiB) Downloaded 33 times
amazighman
mickthemaverick wrote: 31 Mar 2026, 12:04 This may help:
Thank you very much Indeed.
amazighman
Is it advisable to replace the driveshaft oil seal in the transmission?
x 8083
Yes I would as it is cheap by comparison to stripping it all down again should it fail in the future. Plus if you are replacing the shaft then it makes sense to have a new seal to bed to it. :)
amazighman
mickthemaverick wrote: 31 Mar 2026, 16:28 Yes I would as it is cheap by comparison to stripping it all down again should it fail in the future. Plus if you are replacing the shaft then it makes sense to have a new seal to bed to it. :)
Can I be cheeky , and sorry I have been a pain , whats the part number for the seal left side?
Thanks a lot
x 8083
That will have to wait as I cannot access my system at the moment, I will have a look when I can :)
amazighman
🙏 thanks for all your help , Wouldn't have been able to locate the parts without you , my online parts diagram partsouq .com doesn't accept Peugeot vin number , only manual selection which isn't accurate on some parts
Cheers
x 8083
seals.pdf
Copied frm servicebox.
(121.53 KiB) Downloaded 43 times
