Hi all. I have changed the lower wish bones on my C3 Picasso 2011 1.6 hdi
But now the steering seems funny & the nearside wheel camber is out. top of wheel seems in a little
I did change the strut & it all seems OK but cant understand why its driving a little funny
When i increase speed it seams to pull to the left & feels unstable
I don't know if the bush on top of strut in the correct way?
Can anyone please give me some tips on what's wrong
lower wish bone arms
Huskyxantia
- x 928
Re: lower wish bone arms
This may be because your old ones were that worn the tracking was set up correctly to there wear, your need to re track the car , the old fashioned string line method works for me. See video.
Different car but same method
Husky.
moms the word
Done the tracking with New track rod ends it runs ok it only pulls to the left when i increase speed
I am trying to find out if the strut bush on top is the wrong way round.
Huskyxantia
- x 928
Possible then that it may well be .
Have a look at this and study the top mount position
Husky.
Huskyxantia
- x 928
Huskyxantia
- x 928
I think when I did mine the part that slots into the hub assembly was my reference point to line up the top mount I think there's a little u shaped cut away part in the top mount t that lines up with that bit on the suspension leg then I think its the correct way.
Husky.
Huskyxantia
- x 928
Husky.
Huskyxantia
- x 928
The red circled parts these sit on the inner part of the mount housing (the wing)
The top mount has a rubber part thst stick up , this faces inwards whe its fitting to the suspension turret, facing inwards when looking down at the engine bay while standing out side of the car so the driver side one will point right
and the passenger would face pointing left
Husky.
moms the word
Yes looks like there should be a large washer on top of the plastic part that seats the top of spring. then the rubber bearing/Bush goes on
I will remove the strut & see what's going on. but at the moment the top of strut is in too far, giving me a Neg camber \
moms the word
Would there be a difference in size with the wishbones
is it possible that the wrong wishbones have been fitted
I have looked on line & there are some for sale that say
Length 332 mm & others say length 295 mm
any idea's ? I
f i have put the longer 332 mm on the car That would be the problem
any idea's ? I
Huskyxantia
- x 928
id say yes , a few mm would make a noticeable differencemoms the word wrote: 30 Nov 2025, 10:13 Would there be a difference in size with the wishbones
any idea's ? I
Husky.
