How to identify correct suspension type?
jfdelacruz17
Unread post by jfdelacruz17 »
I've been browsing the forums for hours but cant figure this one out.
I'm trying to restore our 508's suspension as there are some creaks and clunks already. However, browsing partsouq.com and entering my VIN, it shows there are two different type of rear suspension for my 508. How do I identify which is the correct one?
The car is a 2013 508 2.0HDi BVA AM6 (DWCTED4)
I'm referring to this:
W2F 5 51A60A: TRAILING ARM REAR SWIVEL PIN
W2F 5 51A65A: TRAILING ARM REAR SWIVEL PIN
There are different part numbers for similar components and I would like to ensure that I order the correct one. I can post my VIN if needed.
-J
x 6946
Re: How to identify correct suspension type?
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
jfdelacruz17
Just donated. My VIN is VF3**************[VIN obfuscated, can be read by forum staff]
Although I've done some research of my own, I'd like to see if my own part number research matches up with the experts here as I am just a beginner DIYer to a French car. I would however, still like to learn/be educated on how to identify the difference and what exactly it is I need myself with regards to the "options" such as:
I would greatly appreciate part numbers of wear/tear components for the front and rear suspension and tie rod/rod ends. These would be any of the arms that have bushings on them and the required nuts/bolts/washers that need to be replaced. Kindly include please the front and rear strut/damper and requisite replacement items for when doing struts like shock mounts, bump stop/covers, etc...
The car has never had any suspension components replaced and is already at 120,000kms and our family has owned the car since new. In Philippine roads this is already a very good life.
-J
x 6946
I'll sort this for you later when I get time.
x 6946
Front Springs
(1) Spring, (2 White, 1 Blue), part: 500440, £184.86
(2) Shock Rod Protector, part: 525453, £18.37
(3) Susp Bump Stop, part: 5033F5, £38.42
(4) Susp Bracket, Left part: 5038H7, £105.05
Right, part: 5038H8, £105.05
(5) Shock Bracket, Left, part: 5038H9, £73.37
Right, part: 5038J0, £73.37
(6) Shock Ball Thrust Bearing, part: 503562, £86.69
(10) Pillar Screw, part: 364819, £2.42
(11) Flanged Bolt, part: 364820, £2.10
(70) Nut & Captive Washer, part: 693680, £3.19
Front Strut
(1) Front Damper Original
Left, part: 5208Y7, £122.75
Right, part: 5208Y8, £122.75
Cheaper Peugeot Alternative
Left, part: 1675682280. £144.73
Right: 1675682380, £144.73
(10) Hex Nut, part: 503615. £5.14
(11) Shock Fixing Screw, part: 521113, £5.74
(12) Shock Fixing Nut, part: 521114, £1.51
Rear Springs
(1) Crossmember, part: 5148Y6, £1225.48
(2) Rear Anti Roll Bar, part: 5170E8, £414.17
(3) ARB Clamp
Left, part: 517259, £49.10
Right, part: 517260, £49.10
(4) ARB Rod, part: 9807130080, £76.27
(5) Rear Crossmember Mountings, part: 515266, £43.18
(6) Rear Crossmember Retainer, part: 516531, £5.72
(7) Bolt, part: 9800917880, £7.30
(8) Flanged Bolt, part: 517322, £2.42
(9) Flanged Bolt, part: 364820, £2.10
(10) Crossmember Plug, part: 515418, £6.80
(11) Flanged Bolt, part: 513276, £4.38
(12) Suspension Spring, part: 5102FS, £157.88
(13) Shock Rod Protector, part: 525457, £16.74
(14) Spring Upper Cup, part: 516533, £22.46
(15) ARB Bearing Clamp,
Left, part: 517261, £48.85
Right, part: 517262, £45.85
(16) Spacer, part: 9810767480, £156.37
(70) Flanged Nut, part: 693686, £
Rear Strut
[/b]
(1) Rear Damper, OEM part: 5206ZC, £
Cheaper Alternative, part: 1623322280
(2) Shock Eye, part: 522074, £
(3) Shock Fixing Screw, part: 1687270780, £
(4) Flat Washer, part: 522439, £
(5) Arm Mounting Protector
Left, part: 521806, £
Right, part: 521807, £
(70) Flanged Nit, part: 693665, £
Front Pivot / Hub
(1) Front Stub Axle Carrier
Left, part: 1640790380, £
Right, part: 1640790580, £
(6) Front Wishbone
OEM Original Left, part: 9666681480, £
OEM Original Right, part: 9666681380, £
Cheaper Left, part: 1682737280, £
Cheaper Right, part: 1682736680, £
(16) Flanged Bolt, part: 364816, £
(17) Flanged Bolt, part: 364817, £
(18) Flanged Bolt, part: 364818, £
(20) Shaft Screw, part: 364824, £
(28) Holding Pin, part: 329703, £
(29) Wheel Hub Fixing Nut: 329433, £
(30) Locking Nut, part: 9808870380, £
(32) Cage Nut, part: 362267, £
(70) Flanged Nut, part: 693686, £2.09
(72) Flanged Nut, part: 693665, £3.19
Rear Hub
(1) Rear Swivel Pin
Left, part: 517654, £600.53
Right, part: 517655, £600.53
(2) Rear Hub Bearing, part: 3748A6, £92.69
(3) Rear Wheel Bearing Nut, part: 373928, £
(4) Wheel Hub Plug, part: 374045, £6.76
(5) ABS Radial Target, part: 454919, £20.02
Rear Trailing Arm
(1) Trailing Arm
Left, part: 9650668480, £407.64
Right, part: 9650668380, £407.64
(2) Rear Suspension Arm
OEM, part:, 5175CF, £225.41
Alternative, part: 1682738780, £29.52
(3) Rear Longitudinal Arm
OEM Left, part: 9801145880, £223.44
Cheaper Left, part: 1682739180, £64.19
OEM Right, part: 9801145780, £223.44
Cheaper Right, part: 1682739280, £64.19
(8) Rear Suspension Link
OEM: part: 517847, £125.41
Cheaper, part: 1682739080, £72.28
(9) Rear Susp Mountings, part: 5131E0, £38.26
(10) Rear Susp Mountings, part: 9801049980, £40.55
(11) Rear Susp Mountings, part: 5131C3, £31.82
(12) Rear Suspension Support Pin, part: 516907, £5.28
(14) Flanged Bolt, part: 5132C4, £6.14
(15) Flanged Bolt, part: 1687270880, £4.52
(16) Shaft Screw, part: 513278, £4.70
(17) Shaft Screw, part: 513280, £4.09
(18) Shaft Screw, part: 513279, £4.48
(19) Buffer, part: 5166C6, £47.89
(20) Rear Swivel Pin
(70) Flanged Nut, part: 693665 £3.19
jfdelacruz17
Awesome! Thanks Givemeabreak!
jfdelacruz17
@GiveMeABreak
Can you also post up part numbers for the front sway bar bushings, Sway bar links and the steering rack tie rods and rod ends? there seems to be a few variations when i look it up on partsouq and i'm unsure which one to get.
x 1496
Front anti roll bar:
Bushing used to be 5094F3, but have been replaced by 509498.
Steering rack end components:
x 6946
jfdelacruz17 wrote: 02 Jul 2024, 10:17 @GiveMeABreak
In future, please use the correct thread for official parts requests (Citroen, DS Automobiles and Peugeot Official Part Number Requests) as this ensures requests are picked up.
jfdelacruz17
thanks GiveMeABreak! Noted on the official thread for part requests. I hadn't seen that one, sorry about that!
