Boxer 1.9D Vin Decode
Jackies Dad
Unread post by Jackies Dad »
Hello Everyone, I have a 2002 Boxer Motorhome and there are a few jobs mounting up, but to get the right parts it would be useful if I could find someone that is able to de-code the VIN .. I can't join the Peugeot service box as I am not a professional repair shop, does anyone have any ideas ?
Would be good to know ! Thanks in advance !! :)
x 6946
Re: Boxer 1.9D Vin Decode
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Jackies Dad
Hi, Thank you for your quick response --- I have donated £10 ( good Value methinks ! )
My VIN Number is VF3**************[VIN obfuscated, can be read by forum staff],
Look forward to hearing from you.
x 6946
Ok so if you require specific part numbers, please use this thread which is only for part number requests and not technical help ( :wink: )
What is it you actually want? If it's factory specs, then here you are:
You have a BOXER SHORT CHASSIS CAB TYPE 10 1.9 TD (XUD9TE) Manual gearbox 5.
Vehicle Characteristics
Vehicle FamilyBoxer
As/Rp N°8597
Warranty Start Date08/01/2001
Engine Serial Number10 Cuku 3015083
General Information
Product TypeCommercial Vehicle
Commercial Marque/Component TypePeugeot
Vehicle FamilyBoxer
SilhouetteShort Chassis Cab Type 10
Trim LevelStandard
EngineTurbo Diesel Xud9te
TransmissionBvm5 4x2
Paint TypeNon-Metallic Paint
Interior Trim Type"Dl" Cathare Cloth
Upholstery Colour"Fr"
Gearbox (Characteristics)Bvm Ml5t
Engine (Type)Xu/Xud
Trim LevelStandard
SteeringPower Steering
Speedometer DriveTacho Torque 25x20
Fuel Supply-Engine
Injection Associated VariantMounting Bosch
FuelDiesel Grade Da/De/De+
Emissions Standard (Engine)Upper Engine Emission Control Eec 95 L3/W3
Pre-FilterAssembly Without Pre-Filter
Speed Sensor SignalWithout Speed Sensor
Engine (Type)Xu/Xud
Catalytic ConverterWithout Catalyst
Oil CoolerMntg Water/Oil Exchanger On Engine
Crankcase Gas Circuit HeatingW/O Heater Casing Gas Circuit
Gearbox Transmission
Final Drive RatioCp 14 X 75
Tyre (Size, Type)Up-Rated 195x70x15 (97 S) Tyres
Reduction GearWithout Reducer
Suspension-Steering-Brakes
AbsW/O Abs Brakes
Brake TypeNon-Ventilated Front Discs/Rear Drums
Front Anti-Roll (Sales Decision)With Front Anti Roll Bar
SuspensionDouble-Leaf Rr Heavy Duty Suspension
Body Fittings
TarpaulinW/O Cover
SkipW/O Flat Hamper
CabinSingle Cab
Third Brake LampW/O Eye Level Rear Lights
Additional Shield (Under Engine)W/O Engine Undershelding
Headlamp WiperW/O Headlamp Wiper
Side Load DoorW/O Side Door
MudflapWithout Mudguard
RoofStandard Roof Pnl
Exterior Rear View Mirror (Driver Side)Outside Drivers Rearview Mirror W/O Control
Exterior Rear View Mirror (Passenger Side)Outside Passenger Rearview Mirror W/O Control
Rear Window (Type)Without Rear Window
Glass (Appearance)Tinted
Side Window (Comm. Veh. Only)Without Side Window
Interior Fittings
Passenger Seat Pack1 Place Passenger Seat
Rear SeatWithout Rear Seat Position
Supplementary SeatWithout Supplementary Seat Positn
Cabin SeatWithout Cab Seat
Circuit BreakerWithout Battery Cut-Off
Front SeatbeltRetractor Without Alarm
Climate (Ambient Temp)Temperate Countries
Supplementary HeaterWithout Additional Heating
TachometerRev Counter With Needle
Driving PositionRight Hand Drive
Additional HeatingWithout Additionnal Heating
TimerWithout Tachograph
Front Passenger Seat AdjustmentWithout Front Passenger’s Seat Adjustment
Front Seat ArmrestAssembly Without Front Elbow Rest
Driver’s Window LiftManual Control Drivers Front Window Lifter
Passenger’s Window LiftManual Control Passeng Front Window Lifter
Oil GaugeOil Level Warning Indicator
Heating ElementNon Heated Seat
Rear Moving PanelWithout Rear Doors
Headlamp Height AdjusterRemote Manual Headlamp Adjustment
Front Seat GuardWithout Cab Protection Panel
RefrigerationWithout Air Conditioning
Driver’s Seat Height ControlFr + Rr Driver Height Adj
Air Con./Temperature RegulationWith Simple Regulation Aircon/Temp
Driver AirbagNo Drivers Air Bag
SwitchElectronic Anti-Theft Key
Water Temp IndicatorWater Temp Indic +Red Telltale
Locking ControlStandard Locking
Electrical
AlternatorAlternator 80 Amp
BatteryBattery L3 400
Starter MotorStarter Motor Cl 5
Component Manufacturers
Miscellaneous
Special SpecificationStandard
Atmospheric ConditionsNormal Atmosphere
Surface ConditionsGood Terrain
