Would be good to know ! Thanks in advance !!
Boxer 1.9D Vin Decode
Jackies Dad
Hello Everyone, I have a 2002 Boxer Motorhome and there are a few jobs mounting up, but to get the right parts it would be useful if I could find someone that is able to de-code the VIN .. I can't join the Peugeot service box as I am not a professional repair shop, does anyone have any ideas ?
- x 6947
Re: Boxer 1.9D Vin Decode
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Jackies Dad
Hi, Thank you for your quick response --- I have donated £10 ( good Value methinks ! )
My VIN Number is VF3**************[VIN obfuscated, can be read by forum staff],
Look forward to hearing from you.
- x 6947
Ok so if you require specific part numbers, please use this thread which is only for part number requests and not technical help (
What is it you actually want? If it's factory specs, then here you are:
You have a BOXER SHORT CHASSIS CAB TYPE 10 1.9 TD (XUD9TE) Manual gearbox 5.
| Vehicle Characteristics | |
| Vehicle Family | Boxer |
| As/Rp N° | 8597 |
| Warranty Start Date | 08/01/2001 |
| Engine Serial Number | 10 Cuku 3015083 |
| General Information | |
| Product Type | Commercial Vehicle |
| Commercial Marque/Component Type | Peugeot |
| Silhouette | Short Chassis Cab Type 10 |
| Trim Level | Standard |
| Engine | Turbo Diesel Xud9te |
| Transmission | Bvm5 4x2 |
| Paint Type | Non-Metallic Paint |
| Interior Trim Type | "Dl" Cathare Cloth |
| Upholstery Colour | "Fr" |
| Gearbox (Characteristics) | Bvm Ml5t |
| Engine (Type) | Xu/Xud |
| Steering | Power Steering |
| Speedometer Drive | Tacho Torque 25x20 |
| Fuel Supply-Engine | |
| Injection Associated Variant | Mounting Bosch |
| Fuel | Diesel Grade Da/De/De+ |
| Emissions Standard (Engine) | Upper Engine Emission Control Eec 95 L3/W3 |
| Pre-Filter | Assembly Without Pre-Filter |
| Speed Sensor Signal | Without Speed Sensor |
| Catalytic Converter | Without Catalyst |
| Oil Cooler | Mntg Water/Oil Exchanger On Engine |
| Crankcase Gas Circuit Heating | W/O Heater Casing Gas Circuit |
| Gearbox Transmission | |
| Final Drive Ratio | Cp 14 X 75 |
| Tyre (Size, Type) | Up-Rated 195x70x15 (97 S) Tyres |
| Reduction Gear | Without Reducer |
| Suspension-Steering-Brakes | |
| Abs | W/O Abs Brakes |
| Brake Type | Non-Ventilated Front Discs/Rear Drums |
| Front Anti-Roll (Sales Decision) | With Front Anti Roll Bar |
| Suspension | Double-Leaf Rr Heavy Duty Suspension |
| Body Fittings | |
| Tarpaulin | W/O Cover |
| Skip | W/O Flat Hamper |
| Cabin | Single Cab |
| Third Brake Lamp | W/O Eye Level Rear Lights |
| Additional Shield (Under Engine) | W/O Engine Undershelding |
| Headlamp Wiper | W/O Headlamp Wiper |
| Side Load Door | W/O Side Door |
| Mudflap | Without Mudguard |
| Roof | Standard Roof Pnl |
| Exterior Rear View Mirror (Driver Side) | Outside Drivers Rearview Mirror W/O Control |
| Exterior Rear View Mirror (Passenger Side) | Outside Passenger Rearview Mirror W/O Control |
| Rear Window (Type) | Without Rear Window |
| Glass (Appearance) | Tinted |
| Side Window (Comm. Veh. Only) | Without Side Window |
| Interior Fittings | |
| Passenger Seat Pack | 1 Place Passenger Seat |
| Rear Seat | Without Rear Seat Position |
| Supplementary Seat | Without Supplementary Seat Positn |
| Cabin Seat | Without Cab Seat |
| Circuit Breaker | Without Battery Cut-Off |
| Front Seatbelt | Retractor Without Alarm |
| Climate (Ambient Temp) | Temperate Countries |
| Supplementary Heater | Without Additional Heating |
| Tachometer | Rev Counter With Needle |
| Driving Position | Right Hand Drive |
| Additional Heating | Without Additionnal Heating |
| Timer | Without Tachograph |
| Front Passenger Seat Adjustment | Without Front Passenger’s Seat Adjustment |
| Front Seat Armrest | Assembly Without Front Elbow Rest |
| Driver’s Window Lift | Manual Control Drivers Front Window Lifter |
| Passenger’s Window Lift | Manual Control Passeng Front Window Lifter |
| Oil Gauge | Oil Level Warning Indicator |
| Heating Element | Non Heated Seat |
| Rear Moving Panel | Without Rear Doors |
| Headlamp Height Adjuster | Remote Manual Headlamp Adjustment |
| Front Seat Guard | Without Cab Protection Panel |
| Refrigeration | Without Air Conditioning |
| Driver’s Seat Height Control | Fr + Rr Driver Height Adj |
| Air Con./Temperature Regulation | With Simple Regulation Aircon/Temp |
| Driver Airbag | No Drivers Air Bag |
| Switch | Electronic Anti-Theft Key |
| Water Temp Indicator | Water Temp Indic +Red Telltale |
| Locking Control | Standard Locking |
| Electrical | |
| Alternator | Alternator 80 Amp |
| Battery | Battery L3 400 |
| Starter Motor | Starter Motor Cl 5 |
| Component Manufacturers | |
| Miscellaneous | |
| Special Specification | Standard |
| Atmospheric Conditions | Normal Atmosphere |
| Surface Conditions | Good Terrain |
