DS3 2012 e-hdi drive belt snapped
sixfoottwo
Unread post by sixfoottwo »
My drive belt snapped on the way home and I've checked the pulleys and the tensioner (the one you see when you open the bonnet) and they all seem ok, is there another hidden tensioner on this car? heard there might be two if it has start/stop (eco mode/stat/stop has never worked)
Any ideas? I've got a belt (Dayco1020) but can't seem to fit it!
Thanks.
sixfoottwo
Re: DS3 2012 e-hdi drive belt snapped
Anyone?
Do all Ds3 1.6 e-hdi's even have start/stop as standard?
x 6960
No they don't all have Stop Start as standard, and as far as fitting the belt goes, yes, you will have tensioners depending on your system, so best get mechanic to do it with appropriate knowledge. There can be 2 dynamic tensioner rollers, so has to be fitted correctly.
sixfoottwo
GiveMeABreak wrote: 30 May 2023, 09:48 No they don't all have Stop Start as standard, and as far as fitting the belt goes, yes, you will have tensioners depending on your system, so best get mechanic to do it with appropriate knowledge. There can be 2 dynamic tensioner rollers, so has to be fitted correctly.
Ok thanks for that.
How do you know it has start/stop then? I was under the impression the e-hdi had them as standard. It has a Eco button and it has lit up green on the dash (not much) in the past, guessing it has it if thats the case?
x 6960
I can tell you for sure if you have it from your VIN (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) if you want to know.
sixfoottwo
GiveMeABreak wrote: 30 May 2023, 13:21 I can tell you for sure if you have it from your VIN (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) if you want to know.
Cheers.
I don't have the vin to hand - car is in my Mums Garage! Can you tell of the reg?
x 6960
I'll need the VIN sorry.
sixfoottwo
GiveMeABreak wrote: 30 May 2023, 16:56 I'll need the VIN sorry.
No worries, just found the V5!
Here we go.
Thanks.
x 6960
Ok, so confirmed you have Stop & Start system and a reversible alternator, with dynamic tensioner rollers.
You need special tools (Dynamic tensioner compression levers and rollers) to fit the new belt correctly. So best left to a competent mechanic to install as there are special procedures and an order to fitting it.
sixfoottwo
GiveMeABreak wrote: 30 May 2023, 18:37 Ok, so confirmed you have Stop & Start system and a reversible alternator, with dynamic tensioner rollers.
Thanks for that as I suspected but it's never really worked!
Bit of a bummer regards fitting as I've bought a belt from eurocarparts thinking it would be a 5minute job like on youtube! never mind will look at getting a few quotes.
Thanks again.
sixfoottwo
Oh I forget to ask, do you know the part numbers for the two tensioners? I'll be looking to replace these with the belt as they advise you to do that I believe.
I take it is part 8 and 9 in the diagram below?
x 6960
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
