C4 Picasso 2017 Hot Air Only on Driver Side
Post your Cit/Peu/Ren air conditioning queries or advice.
chrisnasulea
(Donor 2022)
Unread post by chrisnasulea »
Hi everyone,
I'm very happy to have found this forum! I seem to be having the same problem Janko was describing in this post: viewtopic.php?t=64206
With the heating turned all the way up on both sides I only get hot air on the driver's side. On the passenger's side the air coming in feels like outside air - cold, winter air.
So, I assume the heater matrix is all clogged up and needs replacing. Can you please help me with a suitable part number for my VIN: VF7**************[VIN obfuscated, can be read by forum staff]
I'm also including two pictures of the dashboard as I've seen Picassos with very different layouts on YouTube.
Thank you,
x 3304
Re: C4 Picasso 2017 Hot Air Only on Driver Side
Hi, and :welc: to the forum. It is likely that a flap control has failed for some reason. It looks like your C4P has dual zone climate control. There are flaps that manage the air flow for each side, and if the 'heat' flap stops working on one side that side can no longer adjust the air temperature. It is very unlikely the heater matrix is blocked, as it is used to provide the initial heat for both sides.
x 6956
This vehicle does NOT have dual zone A/C. It is simply regulated for the whole vehicle, hence why there is only one heating control on the touch screen.
The heater matrix can become blocked on one side which can cause this, or it may well be the air mixing or air distribution. Before you go any further, it may well be worth getting a diagnostic first to determine the causes or at least try and rule out the electrical issue.
x 1485
GiveMeABreak wrote: 10 Jan 2022, 13:14 This vehicle does NOT have dual zone A/C. It is simply regulated for the whole vehicle, hence why there is only one heating control on the touch screen.
It does... see the first photo where there are separate temperature scales on the left and right of the screen.
x 6956
I think I had 2 other vehicles on servicebox :roll: and it hadn't cleared the previous one, so yes, I stand corrected James, post amended, thanks Richard.
x 1485
It might not have separate for the rear, but the front definitely is
chrisnasulea
(Donor 2022)
Thank you everyone for your input!
I am going to take the car to a friend's garage in the morning to hook it up to a tester and see if there's any information about failing servos or other electrical issues.
We're probably also going to search for the passenger side hot air flap to see what state it's in. If you have any suggestions as to where that flap might be it will be greatly appreciated. He may already know where to look but more info is always better than less info.
Thanks,
x 6956
I'm afraid it's not that simple if you are going down that road Chris. The flaps are controlled by stepper motors (5) for both the air distribution and air mixing on each side. The 'flaps' are driven by the motors using control rods (14):
Getting to the main heater unit / evaporator is a fascia removal (dash out job). There are some components you may be able to get to by removing either side of the footwell panel trims.
chrisnasulea
(Donor 2022)
It sounds expensive. :)
We won't be removing any dashboards tomorrow. I can't imagine the plastic surviving the procedure in our current sub-zero temperatures without access to a heated garage.
I'll come back here and post some updated info after we have a look at whatever error codes may be showing on the tester.
x 6956
The only downside to testing is that it can only show whether the flap motors are operating or not - I don't believe it can show if the flap is physically moving as that's a mechanical gearing issue. So although the motor spindles may be operating, that won't help if the spindle gears are worn.
When did you last have the coolant system drained and refilled? That may be worth looking at first and if there is a blockage in the heater core they can sometimes force it out via the matrix water pipes when flushing the system through. Worst case scenario is you end up with new coolant and a clean system. If that doesn't sort it then you can investigate further.
chrisnasulea
(Donor 2022)
Hello again,
No error codes were found using the tester.
We opened the panels under the glove compartment and found a part had broken off from the heating unit. I've circled the place where it used to be attached in the 1st picture in red.
I've left the car at my friend's garage and he will try to improvise something to either reattach it or to at least force it to be stuck in the hot position instead of being stuck in the cold position.
Does anyone happen to have access to the instructions for the replacement of the heating unit?
Thanks,
x 8084
Hi Chris,
You may find this video helpful from a similar vehicle :)
x 6956
@ Mick - Mick those are completely different systems to the C4 Picasso (B78). That 407 does not have the same mechanism at all :wink:
chrisnasulea wrote: 12 Jan 2022, 17:41 Hello again,
Thanks,
It's a fascia off to get the heating unit out. Those control arms are on the diagram item (14) that I mentioned earlier.
Item (14) is the Air Conditioning Control Kit, part number: 9821297680, available from Citroen, priced (UK Sterling £112.64).
x 8084
GiveMeABreak wrote: 12 Jan 2022, 18:21 @ Mick - Mick those are completely different systems to the C4 Picasso (B78). That 407 does not have the same mechanism at all :wink:
Fair enough Marc, I thought there were similarities in the flap mechanisms which may have been helpful but obviously not!! I stand corrected! :)
x 6956
No worries, these Picasso ones are a bit more Carlos Fandango-designed with the long control arms that seem to be brittle by the looks of it.
