C3 Picasso Antenna access
Murphyv310
- (Donor 2021)
Hi.
This is my first post here. Thank you for letting me join.
I have an issue with the radio reception on my 2011 C3 Picasso. I am sure its the Antenna.
A couple of questions, Does this antenna have an amplifier and how do you gain access to it via the headlining?
Any help in how to remove sufficient lining would be most helpful.
Thanks in advance.
Thanks in advance.
Cheers Trevor
OnlineHell Razor5543
- x 3296
Re: C3 Picasso Antenna access
Hi, and
to the Forum. Nice avatar (Not now Kato, you fool!
While I cannot offer any useful advice, might I suggest you type the vehicle VIN here? This will allow Forum staff (I am NOT Forum staff) to get more detailed information on your vehicle (provided the relevant manufacturer has granted the Forum staff access to their data). The Forum software will, for security reasons, obscure it so only Forum staff can read it (like this; VF7**************[VIN obfuscated, can be read by forum staff] ). Please do not put any spaces in the VIN, or post up any photographs of it, as the software will not recognise and protect it.
).While I cannot offer any useful advice, might I suggest you type the vehicle VIN here? This will allow Forum staff (I am NOT Forum staff) to get more detailed information on your vehicle (provided the relevant manufacturer has granted the Forum staff access to their data). The Forum software will, for security reasons, obscure it so only Forum staff can read it (like this; VF7**************[VIN obfuscated, can be read by forum staff] ). Please do not put any spaces in the VIN, or post up any photographs of it, as the software will not recognise and protect it.
Murphyv310
- (Donor 2021)
Many thanks Hell Razor.
Here is my Vin VF7**************[VIN obfuscated, can be read by forum staff]
Hope this helps.
Hope this helps.
Cheers Trevor
Murphyv310
- (Donor 2021)
Hi.
Just bumping this thread. Anyone able to help, before I start ripping things out I shouldn't?
Cheers Trevor
- x 6946
Hi Trevor
It isn't an easy affair....
The headlining has to come off officially. At the rear, the grab handles and the seat belt guides also have to be removed as well as the interior light. Officially, the whole headlining should be removed, which would also mean the front grab rails and sun visors as per the following:
(1) Headlining.
(2) Seat belt guide (rear).
(3) The mounting cover of the child seat attachment cover.
(4) Rear interior lamp.
(5) Grab handles.
(6) Sun visor.
But to do all that involves removing the quarter panel trims, the screen pillar trim pads and the roof console etc.
Whether you can get to it partially without doing this I can't tell you, but thios is the base and the immediate aerial wiring:
The aerial base nut is shown at (1).
Looking at the following the aerial module is located at (3), so may not be possible to access without fully removing the headlining.
But having looked at the wiring, you may not have item (3) as that may be for additional equipment - I can't be 100% sure.
Here's the unit again, so you may be able to get to this without all the removal if you can find a way in....
(1) Headlining.
(5) Grab handles.
(6) Sun visor.
Murphyv310
- (Donor 2021)
Hi Marc.
Many thanks for the helpful diagrams. I'll need to now reconsider if I'll go down this route.
Seems like a big job.
Cheers Trevor
- x 1941
What exactly is the problem with the reception? Is it restricted to one waveband or does it affect all?
Murphyv310
- (Donor 2021)
Hi.
Both AM medium wave and FM are poor. The original Citroen headunit was very poor but a Pioneer unit I've fitted is a bit better on both bands. I did wonder if the supply to the antenna amp was missing.
My car is the base model, no aircon, fancy radio etc.
Cheers Trevor
- x 1941
Ah, so you've changed from the standard PSA unit to an aftermarket radio. That puts a different slant on things.
AFAIK the aerial units have amplifiers and require a power feed to them, as you have already said. The method of delivering the power changes according to the model. Some have a separate wire to the amplifier and others have 12v inserted into the aerial co-ax. It's possible that the amplifier isn't being powered up even assuming that the Pioneer has the option to power an amplifier.
Marc or Wheeler should be able to tell you which type of power feed the amplifier has from the VIN.
Further thoughts. You said that the problem was worse when the original radio was in. Did you try anything to make it better or did you jump straight to the Pioneer. What model was the original radio?
Murphyv310
- (Donor 2021)
Hi.
The reason for going to the Pioneer was for phone connectivity and MP3 from a memory stick. I didnt realise the aerial could be Bias T fed via the coax.
The original radio is a Bosch PSA N1 MP3 DXM
Also marked Bosch CM RD4 N1 MP3-03 96 669 595 77 dated 10-03-11
Cheers Trevor
- x 6946
Original kit is a basic RD4, mono tuner - so 1 active aerial and that's it, no USB connecting box or hands free kit.
Murphyv310
- (Donor 2021)
- x 1941
Yes but what kind of feed is the 12v power for the amplifier? Is the amplifier a separate unit or in the base of the antenna unit?GiveMeABreak wrote: 14 Aug 2021, 14:06 Original kit is a basic RD4, mono tuner - so 1 active aerial and that's it, no USB connecting box or hands free kit.
- x 6946
Not shown as a separate amp so fed from RD4 originally I suspect.
Murphyv310
- (Donor 2021)
So if its not showing an amp it's just a straight aerial directly fed to the radio antenna socket.
Cheers Trevor
