Injector Clamp Torque Setting
essa
Unread post by essa »
Hey, I'm after the Injector clamp bolt torque setting for a C3 2011 1.4hdi Vin No: VF7**************[VIN obfuscated, can be read by forum staff].
I'm struggling to find the setting, hope some one can help.
thankyou
x 6945
Re: Injector Clamp Torque Setting
Here you go:
ReferenceDesignationStageTightening Torque
(1)Connections (Diesel Injector)Pre-Tighten2 Danm
(1)"Tightening2,5 Danm
(2)Connections (Fuel High Pressure Pipes / Fuel High Pressure Common Injection Rail)Pre-Tighten2 Danm
(2)"Tightening2,5 Danm
(3)Union (High-Pressure Fuel Pipe / Fuel High Pressure Pump)Pre-Tighten2 Danm
(3)"Tightening2,5 Danm
(4)Bolts (Fuel High Pressure Pump Rear Bracket)Tightening1 Danm
(5)Bolts (Fuel High Pressure Pump Rear Bracket)Tightening1 Danm
(6)Bolts (Diesel Injector Fixing Flange)Pre-Tighten0,7 Danm
(6)"Angular Tightening80°
(7)Bolts (Fuel High Pressure Pump Front Bracket)Tightening2 Danm
(8)Bolts (Fuel Injection Pump / Bracket )Tightening2 Danm
(9)Fuel Injection Pump Pulley NutTightening5 Danm
(10)Bolts (Fuel High Pressure Pump Rear Bracket)Tightening2 Danm
(11)Bolts (Fuel High Pressure Common Injection Rail / Engine Block)Tightening2 Danm
(12)Fuel High Pressure SensorTightening4,5 Danm
(13)Bolts (Fuel Pressure Regulator / Fuel High Pressure Pump)Pre-Tighten0,3 Danm
(13)"Tightening0,7 Danm
essa
thankyou very much @GiveMeABreak, so I guess its number 6 I'm looking at for the clamp bolts what 0.7 danm in nm? is that 7nm?
Steve Walsh
x 518
Unread post by Steve Walsh »
7nm
5.6 ft/lb
61.9 in/lb
essa
7nm + 80 degree thankyou
