Hey, I'm after the Injector clamp bolt torque setting for a C3 2011 1.4hdi Vin No: VF7**************[VIN obfuscated, can be read by forum staff].
I'm struggling to find the setting, hope some one can help.
thankyou
Injector Clamp Torque Setting
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Injector Clamp Torque Setting
Here you go:
Reference | Designation | Stage | Tightening Torque |
(1) | Connections (Diesel Injector) | Pre-Tighten | 2 Danm |
(1) | " | Tightening | 2,5 Danm |
(2) | Connections (Fuel High Pressure Pipes / Fuel High Pressure Common Injection Rail) | Pre-Tighten | 2 Danm |
(2) | " | Tightening | 2,5 Danm |
(3) | Union (High-Pressure Fuel Pipe / Fuel High Pressure Pump) | Pre-Tighten | 2 Danm |
(3) | " | Tightening | 2,5 Danm |
(4) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 1 Danm |
(5) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 1 Danm |
(6) | Bolts (Diesel Injector Fixing Flange) | Pre-Tighten | 0,7 Danm |
(6) | " | Angular Tightening | 80° |
(7) | Bolts (Fuel High Pressure Pump Front Bracket) | Tightening | 2 Danm |
(8) | Bolts (Fuel Injection Pump / Bracket ) | Tightening | 2 Danm |
(9) | Fuel Injection Pump Pulley Nut | Tightening | 5 Danm |
(10) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 2 Danm |
(11) | Bolts (Fuel High Pressure Common Injection Rail / Engine Block) | Tightening | 2 Danm |
(12) | Fuel High Pressure Sensor | Tightening | 4,5 Danm |
(13) | Bolts (Fuel Pressure Regulator / Fuel High Pressure Pump) | Pre-Tighten | 0,3 Danm |
(13) | " | Tightening | 0,7 Danm |
- My Cars: citroen c3 connxtion 2010 1.4hdi
thankyou very much @GiveMeABreak, so I guess its number 6 I'm looking at for the clamp bolts what 0.7 danm in nm? is that 7nm?
- My Cars: C5 Aircross 2021 VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Kawasaki ZR1100 1994
C4 Hatchback
Yamaha XVS650A 2001 - x 364
7nm
5.6 ft/lb
61.9 in/lb
5.6 ft/lb
61.9 in/lb
Thanx to Marc and all the admins & knowledgeable people that make this the best forum on the interweb.
7nm + 80 degree thankyou
