Hey, I'm after the Injector clamp bolt torque setting for a C3 2011 1.4hdi Vin No: VF7**************[VIN obfuscated, can be read by forum staff].
I'm struggling to find the setting, hope some one can help.
thankyou
Injector Clamp Torque Setting
- x 6948
Re: Injector Clamp Torque Setting
Here you go:
| Reference | Designation | Stage | Tightening Torque |
| (1) | Connections (Diesel Injector) | Pre-Tighten | 2 Danm |
| (1) | " | Tightening | 2,5 Danm |
| (2) | Connections (Fuel High Pressure Pipes / Fuel High Pressure Common Injection Rail) | Pre-Tighten | 2 Danm |
| (2) | " | Tightening | 2,5 Danm |
| (3) | Union (High-Pressure Fuel Pipe / Fuel High Pressure Pump) | Pre-Tighten | 2 Danm |
| (3) | " | Tightening | 2,5 Danm |
| (4) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 1 Danm |
| (5) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 1 Danm |
| (6) | Bolts (Diesel Injector Fixing Flange) | Pre-Tighten | 0,7 Danm |
| (6) | " | Angular Tightening | 80° |
| (7) | Bolts (Fuel High Pressure Pump Front Bracket) | Tightening | 2 Danm |
| (8) | Bolts (Fuel Injection Pump / Bracket ) | Tightening | 2 Danm |
| (9) | Fuel Injection Pump Pulley Nut | Tightening | 5 Danm |
| (10) | Bolts (Fuel High Pressure Pump Rear Bracket) | Tightening | 2 Danm |
| (11) | Bolts (Fuel High Pressure Common Injection Rail / Engine Block) | Tightening | 2 Danm |
| (12) | Fuel High Pressure Sensor | Tightening | 4,5 Danm |
| (13) | Bolts (Fuel Pressure Regulator / Fuel High Pressure Pump) | Pre-Tighten | 0,3 Danm |
| (13) | " | Tightening | 0,7 Danm |
essa
thankyou very much @GiveMeABreak, so I guess its number 6 I'm looking at for the clamp bolts what 0.7 danm in nm? is that 7nm?
Steve Walsh
- x 518
7nm
5.6 ft/lb
61.9 in/lb
5.6 ft/lb
61.9 in/lb
essa
7nm + 80 degree thankyou
