C5 X7 Chrome door "rubbing strip" removal
Argos69
x 59
Unread post by Argos69 »
Hi all,
I've just swapped my old C5 X7 VTR+ for a newer Exclusive, which seems in overall good condition except it's had a scrape on the driver's side rear door Rubbing Strip (if that's the correct name for it!). It's chromed plastic I think. I've been quoted around £90-£100 for a replacement, so thought I might give some mirror car wrap film a go first. Question.....
Is it clipped or stuck on and what's the recommended technique for removal without any collateral damage?
Does anyone know the part number for the strip and any clips involved.
Thanks in advance for any help - Keep safe and well.
2010 Land Rover Freelander 2 HSE Automatic
2013 Citroen C5 Tourer 2.2HDi Exclusive
2017 Citroen Berlingo Multispace Flair 120 Gone!
2012 Citroen C5 Tourer 1.6HDi 6 Speed (sort of auto!) Gone!
2012 Citroen Berlingo Enterprise 1.6HDi Van Gone!
2001 Range Rover 4.6 Vogue Gone!
x 6947
Re: C5 X7 Chrome door "rubbing strip" removal
Please see the info below for live parts information: A £10 min donation will cover you for parts info and parts diagrams for up to 2 years.
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
We'll then need a VIN if you want to go ahead.
Argos69
x 59
Hi again,
Donation gladly made (really appreciate all the help I get here!).
My Vin is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks again :-)
x 6947
Great, thanks for that.
Have a look at the diagram above.
I think item (10) is what you are after, but correct me if I'm wrong. Chromium Grey is the colour for your car and this is reflected in the part numbers below:
The rear left side door protector part number is: 8546W5
The rear right side door protector part number is: 8546W7
Both are £100.15 each inc. VAT from Citroen as of today.
As for fitting:
Unclip the clips (at "t") using trim removal tools.
Remove: The protector (45).
The clips item (20), are part number: 856564 and cost £2.95 each and need to be replaced if they break on removal of course .
Argos69
x 59
Thank you!
