Changing DS3 fuel injector
tomjyoutwit
- x 5
Good Afternoon,
I have to replace my fuel injector on my 2011 1.6 diesel, has anyone a guide available or any tips? I've got the airbox off and it seems relatively straight forward but don't want to make a mistake!
- x 1930
Re: Changing DS3 fuel injector
I'm just about to do this very job on our 2015 Peugeot 308 Blue HDi. I already have the S/H injector and am just waiting for the new clamp bolt to arrive.
If you have a look at my thread here viewtopic.php?t=64451, probably from about half-way down the second page will be relevant. Follow the link that Marc posted for a diagram of the top of the injector.
From what I can see there's nothing specific to be aware of. The clamp bolt is a stretch bolt and should be replaced. Tightening instructions are 7nM and then +85°. You're supposed to replace the supply pipe as well but I'm going to try to reuse that to start off with.
tomjyoutwit
- x 5
Thanks Paul, hugely appreciated.
The little green nub is my current sticking point so will try that shortly.
Also worried I have the wrong replacement for VIN VF7**************[VIN obfuscated, can be read by forum staff]
- x 6955
Tom - if you need specific and current live parts data for your vehicle, PSA now charge for this, so we ask for a small donation to the Forum to cover any parts access you may need for up to 2 years - details below:
| A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
| Donate Further Information |
- x 1056
That's meant to be the case for all PSA HDi engines if the pipes have been removed. I have removed & refitted literally hundreds of them & never had any issues.Paul-R wrote: 29 Jun 2020, 15:14 You're supposed to replace the supply pipe as well but I'm going to try to reuse that to start off with.
tomjyoutwit
- x 5
Hi Marc I’ve made a donation.
Think I need a new supply pipe anyway due to my ham fistedness.
- x 1930
That's the leak-off hose assembly. it's not under any great pressure. How did you manage to damage it?
Also, can you post a photo of the top of the injector like I did in my post?
tomjyoutwit
- x 5
Dad took the hex off beneath the injector and snapped it
These are all the photos I have - let me know and I can provide more tomorrow
- x 1930
A photo of the top of the injector - assuming yours is similar to mine. Something like this one on our car.
tomjyoutwit
- x 5
- x 1930
OK, that's a Siemens injector. As seen in this Ebay offering https://www.ebay.co.uk/itm/CITROEN-PEUG ... SwZDxeOalr
I think you said you wanted the leak-off pipes but this was all I could find without a part number. I'm not about their condition though! https://www.ebay.co.uk/itm/2012-MAZDA-F ... SwQKteblQW
- x 1930
One further thought. When I eventually change the injector in our car (the damn clamp bolts didn't arrive again today) it has to be coded in to the car. Perhaps it's the same for you?
- x 6955
Thanks for that Tom.tomjyoutwit wrote: 29 Jun 2020, 18:40 Hi Marc I’ve made a donation.
Ok, so your injectors are Continental (formerly Siemens).
There was a replacement part number for the new ones: 9802448680 (£459.10 each) or the cheaper version, part number: 1608518380 (£364.68)
As for the Return hose:
That also has a replacement part number: 1574HX priced at £27.48.
All prices correct as of post date direct from Citroen and include VAT.
tomjyoutwit
- x 5
Thanks both- does anyone have a clear guide of how to remove the damn thing? All connections are off of it but the injector is not free from the engine.
- x 6955
I can put something up for you Tuesday Tom.
