C5 X7 RD4 to RT6 Inc HiFI Upgrade
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
Martin1980
Unread post by Martin1980 »
Is it possible to replace the original speakers with those of HI FI System? I have everything amp,suwoofer,speakers and wires.
x 1940
Re: C5 X7 RD4 to RT6 Inc HiFI Upgrade
Unread post by Paul-R »
There's a thread on the Peugeot Forums website regarding changing the standard door speakers for Focal items in the Mk2 308.
https://www.comics.org/searchNew/?q=%22 ... 0DeWalt%22
Now, several caveats here:
I haven't done this for our 308.
Therefore I haven't been able to check if they're a straight fit in my X7.
This is to improve the sound quality of the standard system - I have no idea of their power handling capabilities.
Later on in the thread there's talk about the focal tweeters. Apparently the standard tweeters use a simple capacitor bypass but the Focal tweeters have a separate feed.
x 6945
Martin1980 wrote: 15 Jun 2019, 07:40 Is it possible to replace the original speakers with those of HI FI System? I have everything amp,suwoofer,speakers and wires.
If you are referring to the optional Philips Hi-Fi system, then this is a multiplexed amplifier.
It takes the 4 audio outputs and converts these into 8 amplified outputs:
  • 2 front woofer outputs
  • 2 outputs for the front tweeters
  • 2 rear speaker outputs
  • 2 outputs for the bass box
The connection to the audio amplifier is by means of 3 connectors (The 3 connectors are of the SICMA 16-way type).
  • The black connector transmits the low power information and the supplies.
  • The blue connector transmits the power information to the right-hand speakers.
  • The white connector transmits the power information to the left-hand speakers.
If you need the pin out connections from the 3 Equaliser 16 block connectors let me know.
Martin1980
Will I have to modify my installation?I have almost all wires from the car.Were is the amplifier`s place?Could you give me the pin out connections from the 3 Equaliser 16 block connectors?
x 1940
I rather suspect you're going to have to plough your own furrow here. Did the kit come with any instructions? Marc can probably tell you where the amp would sit for the standard upgrade but whether yours will physically fit is another matter. And then, because the standard upgrade integrates into the data system, you'd have to install the wiring yourself and then see if your speakers can be persuaded to fit. Or, if the speakers are too difficult to fit and the power handling capabilities are similar think about the Focal speakers providing they physically fit better of course.
Much to think about there and you may find it easier to engage the services of a professional car audio firm. Or sell it on and start again? How much did the kit cost? Have you had it fitted to another car before? Is it new?
x 6945
That looks like an X7 wiring loom that has been taken out of another vehicle - that's not going to be a practical option in my opinion without dismantling half the car! It's another reason why they supply repair kits for harnesses.
There are many, many different harnesses, and they are dependent on left / right hand drive, whether a telematic unit is fitted or not and what type of head unit, services module is fitted or not, engine type, equaliser option or not, etc., etc. Also, don't forget that the wiring harnesses changed depending on the build number of the vehicle too.
There are 38 different versions of the intermediate harness alone! Fitting apart, how did you determine the correct harness part number for your car with the correct options you want to fit? Cars with telematics units like the NG4 / RNEG / RT6 already have different harnesses at factory fit than a standard model with RD4 system - and then these go into different part numbers depending on the options as I mentioned above.
Anyway, if it helps, here are the connections from the HiFi Amp:
"a"16-way Black Connector
Channel NumberAllocation of Channels of Connector
1Unused
2CAN +
3Unused
4Right-hand audio system + input
5Right-hand audio system - input
6Unused
7CAN High
8Unused
9Battery +
10Unused
11Left-hand audio system - input
12Left-hand audio system + input
13Unused
14VAN Low
15Unused
16Earth
"b"Bonnet Locking 16
1Front left tweeter +
2+ Front LH woofer speaker
3Unused
4Rear door left-hand speaker +
5Unused
6Left-hand bass module +
7Unused
8Unused
9Front left tweeter -
10- Front LH woofer speaker
11Unused
12Rear door left-hand speaker -
13Unused
14Left-hand bass module -
15Unused
16Unused
"c"16-way Blue Connector
1Front right tweeter +
2+ Front RH woofer speaker
3Unused
4Rear door right-hand speaker +
5Unused
6Right-hand bass module +
7Unused
8Unused
11Unused
13Unused
15Unused
16Unused
x 6945
I've moved this to the telematics section and changed the title to better reflect what it is you are asking / wanting to do.
Martin1980
My car original was with RT4. Now is with NG4 no service module. I fine this kit from C5X7 with HI FI System for 280£. I hope that will be easy to install. Thanks for the help and info.
Fortius
Unread post by Fortius »
Thanks for the schematics, but something is missing:
- the rear tweeters, where are the rear tweeters are connected too?
- the input in the amplifier from the head unit - from my knowledge the head unit doesn't have an output for the amplifier. So, if this is true from where I can get the signal for the amplifier?
