I need a wiring diagram for 2015 DW10FD 2.0 Hdi diesel. Or pin chart to identify wiring around engine. (Especially TPS / accelerator /ECU.)
Anyone help? That engine has been out since around 2014 or even earlier in the C4 Picasso so must be one available by now?
2015 C5 DW10FD WIRING DIAGRAM NEEDED
admiral51
- (Donor 2026)
- x 391
Re: 2015 C5 DW10FD WIRING DIAGRAM NEEDED
post your vin number up and i am sure someone will provide you with the details
Johnd993
- x 3
Ok thanks, vin is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6946
So the Throttle Position Sensor 1261 (built into the Accelerator pedal) should have a brown 6 pin connector. This goes to the Engine ECU, 53 Pin Black connector as shown below with pins:
Wiring
1380Z: + 5 volt accelerator pedal position indicator power supply
1378D: Accelerator pedal 2 position info
1466D: accelerator pedal 2 position earth
731D: accelerator pedal point of resistance / signal
1379D: accelerator pedal position earth
1377D: Accelerator pedal 1 position info
Wiring
Johnd993
- x 3
Thats great - thankyou. I have an auto electrician coming to go through it soon. I wonder if you have access to similar chart for the throttle position sensor also? The expected voltages / resistance etc of each would be a great help. ( Sorry I know its a big ask.)
- x 6946
That is the throttle position sensor - it is built into the accelerator pedal. This then goes direct to the Engine Management ECU.
Johnd993
- x 3
Hi Marc, I'm talking about the butterfly throttle on the intake. Theres a throttle position sensor on it with a 5 pin pigtail connecter. Its the 3 parts required for throttle response. Accelerator, Throttle position sensor on intake and of course the ECU. I have replaced all 3 so just need to fathom out wiring between each now. (I actually suspect wiring from intake most -as after fiddling one time there -it behaved for a while.)
- x 6946
Ok, so we refer to that as the Air Doser, part of the Turbo air piping, hence the confusion.
Part A in the diagram.
As for the diagram - I will be sending you a PM shortly.
Johnd993
- x 3
Oh ok. Seems i’m on the wrong track then? My code reader is saying discrepancy between the two potentiometers from the throttle position sensor. So perhaps I should concentrate on replacing connectors and wires from accelerator to ECU - as your diagram 1261 above.
I do appreciate the help you’re giving me.
- x 6946
John, what actual codes are you getting from your reader? It may be a code I can refer to an earlier Delphi system for a better explanation.
