C4 VTS - Adding front parking sensors
lancia58
- x 8
Hi
My 2006 2.0 16v C4 VTS has rear parking sensor. I want to add front parking sensor. IIRC I read in a forum that in C4 VTS the harness for front parking sensors is installed and only the sensors should be installed as well as configuring the BSI . How can I know if the harness in installed ?
Zohar
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 6957
Re: C4 VTS - Adding front parking sensors
For this C4 model, there were several parking ECUs depending on build date, but unlike the C5, the one you currently have for rear only would seem to be configurable for front and rear parking options and would not appear to require another ECU.
Obviously you will need the relevant sensor supports and trim in addition to the sensors.
It would also seem that you already have the supplementary front harness in place according to your VIN to answer your question.
See the second diagram for the harness which is item (1). The second harness (2) is for AFIL only.
lancia58
- x 8
What is Citroen part number for the front harness ?
Zohar
Zohar
- x 6957
Harness number (1) has a part number of 6568 86. This is the harness that should be fitted to your car already.
lancia58
- x 8
I checked online at Citroen service it my car includes that harness
- x 6957
So once you have the parts you just need to reconfigure the Parking Assistance ECU for Front and Rear. You may also need to configure the Head Unit ECU also to account for the change. I'll check later.
lancia58
- x 8
Can the Harness (6568 86 ) be seen through the grill of the front bumper , I looked for it through the front bumper gill and didn't find it
Zohar
Zohar
- x 6957
I doubt it, the harness is probably tucked up behind the bumper - and as you don't already have the front obstacle detector sensors fitted, there won't be any reason for the wiring to be dropped down at each sensor point - so the sensor wiring drop down wires may be clipped / tied to the main loom. A bit of investigation work will be involved.
bloodjean
Hello,
This weekend I tried to install the front parking sensors on my C4.
I already have the rear parking sensors.
Both Parking Assistance ECU and Head Unit ECU are compatible because I could program it with the front and rear mode.
So I decided to install the front parking sensor and to connect it to the connector pre-installed under the hood.
It occurred that I've got an error with the front parking sensor. I then realise with a scheme that the harness isn't connected to the Parking Assistance ECU. I discovered some wires not connected near this area (not sure it could be for front parking sensor) but there is no continuity with the harness under the hood. So I don't understand, could it be possible that the harness is partially installed ? From the hood to the back Parking Assistance ECU is there an other connector ?
- x 6957
Pop your VIN up and I’ll check the harnesses.
bloodjean
- x 6957
Your build date 10789
ECU part numbers 6590 N5 (to be Configured) or N6 (Pre-configured) are what you have and I have confirmed that these also support front parking assistance too, so that is ok.
Your issue is going to be the lack of wiring harness from the front sensors to the rear Parking assistance ECU. Think about it - if the front sensor harness is already there on models without it (pre-wired) and the ECU is compatible, - then there would already be front and rear assistance on all vehicles with rear parking!
So you probably have a different intermediate harness which carries the wiring to the rear ECU and that is why they are not functional.
bloodjean
So what should I do ?
- x 6957
There are loads of harnesses - Engine, Supplementary, Front, Fascia, Intermediate, Seat Belts, Rear, Tailgate and others - so I can't tell you which one of these you need unfortunately. It would be a hell of a job to change the harness now - that's why they do a repair kit as they are not easy to replace once the car is assembled with all the trim in place.
Just to make it harder, the harnesses are fifferent for left and right hand drive models and again on 3 / 5 door models and again on the build date.
If I had the VIN from a C4 of the same model, engine and year with the Front & Rear factory fitted Parking Assistance system already fitted - I would at least be able to compare the harness part numbers and see which ones are different.....
- x 1461
There should I think be a wiring harness diagram which gives details of which harness each circuit connects through (on a car with the option fitted), this would at least tell you which harnesses and connector blocks to inspect.
