x 8122
Post by mickthemaverick »
Got the coping stones fitted on Wednesday and now just finished adding the last stones along the front edge. Looks better now than it ever did!! :-D
A finished job!
A finished job!
x 5672
Post by myglaren »
Ammo for the local scallies!
x 8122
The waterfall is behind a locked gate Steve so they'll have to work for it! :-D
Skull
(Donor 2026)
x 381
.DIY with function over finesse!!.
Post by Skull »
This is going to be my last big DIY job for my Daughter ...the fully tiled shower room was (imo) the best finished room in the house but she want a makeover so I've convinced her to let me do a partial makeover and save a few grand ...
Shower tray removed and the bonding resin and sub floor put up a fight, just so I can tap into the water feeds for a short bath (1400mm) (she loves a bath)
Skull's - DIY
Skull's - DIY
This is what greeted me .... butchered joists re-inforced :^o with chipboard and plywood, builders rubble/offcuts and plastic speedfit connections :roll:
I'm ignoring the state under there and am just going to join on but I don't think I've ever used speedfit fittings before :dunno:
Skull's - Spagetti Speedfit
Wish me luck [-o<
Gary
PaulC5
x 685
Post by PaulC5 »
First time I came across a speedfit type of fitting was a student rented house and it had come loose so the kitchen floor was flooded. Important to check they are fitted correctly especially if hidden.
x 8391
Re: .DIY with function over finesse!!.
Post by CitroJim »
Good work Gary :D
That looks a bit like my bathroom did when they gutted it!
Skull wrote: Yesterday, 15:20 I don't think I've ever used speedfit fittings before :dunno:
I was very dubious about them first time I ever encountered them but generally they are bloody excellent... My house now has a lot both in my bathroom and on the new central heating. Touch-wood, never a problem.
No need to worry ;)
John Pankhurst
(Donor 2026)
x 44
Post by John Pankhurst »
I've used them once when installing a shower cubicle. Really awkward access to the under floor connections for normal copper fittings but the speedfit worked out well.
Sloppysod
x 396
Post by Sloppysod »
Only ever used copper push fit connectors, because my gas bottle run out and could not get a replacement - it was my Dads!
Seen a few plastic pipe installations with sagging pipes, if I were to use it I would add as many clips as possible or even a (as well) a support batton.
And why the elbow.?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Skull
(Donor 2026)
x 381
Post by Skull »
Sloppysod wrote: Today, 10:22.
…….And why the elbow.?
I think it was to get the cold pipe below the shower tray, in that corner but there’s also a large chunk of joist missing in that area and a brick missing from the interior wall where I presume the original bath waste pipe went to a hopper outside. Which I will use to run the new bath waste through and tidy up the exterior scab of cement …hopefully I can alter that to take some tension off that area ….
Gary
