206cc to a 308cc How ? Why ? Everything 308cc
Huskyxantia
- x 908
Re: 206cc to a 308cc How ? Why ? Everything 308cc
Ok, a slight diesel smell no where as strong but it could be the foam insulation covering might , well it maybe holding what was leaked into it , my plan is to renew all the o rings so a new set is in order green ones aswell.
308cc dusty and playing hide n seek lol
Husky.
Huskyxantia
- x 908
The photo I put wore , should of been wire, spell correct thing going nuts .
Husky.
Huskyxantia
- x 908
So fingers crossed them o rings turn up to day so I will swap them out for new .
Husky.
Huskyxantia
- x 908
Never saw this till it was removed looks like an old repair this part is tucked away from view .
Husky.
Huskyxantia
- x 908
Its slowly coming off ... and the heat is building too
Husky.
- x 5669
The knife caught my eye as I have one similar to it. They were used in the factory where I used to work to trim the plastic beads in uPVC window frames.
Bought mine from eBay and found it very useful.
Huskyxantia
- x 908
It was left behind when I had a new door fitted to the house 3 years ago its been very handy plus no ones ever come back for it .
So far its going steady ive never done this before but
Husky.
Huskyxantia
- x 908
Well that fits nice
Husky.
Huskyxantia
- x 908
Carefully prise these out amd slot back into the housing on the back of the liner then it will clip back in easier, when you remove it you unclip the front first then push the liner back toward the back window and it slides off , clips then needed popping out then fitting back into liner
Husky.
- x 8385
Looking good husky
Huskyxantia
- x 908
All nice and new looking again , apart from the roof now kicking up a fuss so ive got to do the manual reset . Oh well
Husky.
Huskyxantia
- x 908
So the roof is almost home the boot has lowered over night , all windows work so thst rules out the know window issue that stops the roof working, tbh wished I'd never bothered doing the liner but it looks so much better than before, the release valve is still open and im leaving it to do its own thing , plus ive a rachet strap doing its thing aswell , it only needs to go another 8 inches .... hurry up , at least its not wet ..... or have I tempted fate !
Husky.
- x 2341
Fantastic work on that headliner, Husky!
Huskyxantia
- x 908
Thanks matt , ive got the roof almost shut now but found the part that folds behind rear seats, has got caught on the rear window and is stopping full closing , so when I got some free time, and when its cooler yet another manual reset to sort this out , ive covered the car with a tarp as a just incase , its all locked fully and wrapped up , so can wait for a bit.
Husky.
Huskyxantia
- x 908
Manually closed the roof finally and the new liner looks ok
Husky.
