Lexie installation problems
x 3296
Re: Lexie installation problems
Windows 7 should run the Diagbox software. My netbook is running Windows 7 Home.
taffy
Unread post by taffy »
I've got diagbix on win 7 bought of eBay runs great
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
Huskyxantia
x 918
Unread post by Huskyxantia »
Hopefully by mid next week i should have my setup done and all fully running. I contacted the fella i purchased the software from he said I'm not the first to get back to him and going back to 32bit fresh install on the laptop will cure the problem .
I want to thank James for your help your like a swiss army knife
:-D
x 3296
Do NOT forget to back up that file (that Marc mentioned) for every update.
Huskyxantia
x 918
Thats all on my usb stick,with all the new drivers to the laptop.
Ive just purchased a new air intake for the 206 as the old one has come to the point of leaking to much oil down the side of the engine , when the weathers warm it makes oil far more worse than what it is, another little job , always something with cars.
:-D
Huskyxantia
x 918
Win7 pro 32bit now up and running now ive got this
Diagbox is 7.2, ive still got the rest of the updates to install i think my interface is 7.5 is this the reason for the screen shot.
:-D
x 3296
Sometimes it helps to plug the equipment into each of the USB ports, so the software can find it whichever port it is connected to. You might want to do this after each successful upgrade.
DON'T FORGET TO BACKUP THAT FILE!!!
Huskyxantia
x 918
File backed up on my usb stick all safe, it updated the driver for the usb when i plugged the interface in then i rebooted the laptop again its the rest of the updates to do which im to knackered to do but im getting there. The place were your brough your lexia are currently out of stock !
:-D
x 3296
Easy Diagnostics regularly sell out of Lexia stock, which could indicate how good their stuff is.
Huskyxantia
x 918
Used my setup this morning it can't talk to all the ecu's but it is working , ive still the 8 off line updates to do which after a day of hay and straw baling and making a fire break on the small holding, i will leave it to another day when im not so busy, at least its not nagging about anything.
:-D
Huskyxantia
x 918
8-[ what ?
:-D
Huskyxantia
x 918
Found a large hole in the air box where its been hitting the egr valve solenoid, holes sorted , new egr valve on today the screen shots where before both jobs were done, the bottom screen shot ? Was my 307.. jabberings of a none earth like lingo !
:-D
parnell
(Donor 2022)
x 12
Unread post by parnell »
I had a DPF error message (P1447) on my car come up - so I took out the old XP laptop I had managed to get diagbox to install on beforehand - it could see the VIN straight away but complained about VCI communication and wouldnt go any further. Stupidly I thought "Ok I didnt have this problem before so I will reinstall everything"... nearly 20 hours of work reinstalling windows XP and I cant get past this 61997080.ulp issue on installation... absolutely going crazy now as the wife needs the car soon...please help
x 1940
I have never heard of '61997080.ulp' before. At what point in the installation does it occur? Is it a Windows XP or a Diagbox message?
parnell
(Donor 2022)
x 12
Paul-R wrote: 19 Jul 2026, 16:25 I have never heard of '61997080.ulp' before. At what point in the installation does it occur? Is it a Windows XP or a Diagbox message?
Hi Paul , it occurs on the installation of the calculo module within diagbox. Im trying on Windows XP 32 bit. Its also mentioned on the very first post on this thread. However I have a completely fresh XP installation so this is absolutely killing me... thanks a lot for the support. If its of any value I have the 921815C hardware interface.
