Stiff suspension after spheres regassing - C5 X7
GolfMk1Vr6
Re: Stiff suspension after spheres regassing - C5 X7
Unread post by GolfMk1Vr6 »
Kees wrote: 21 Apr 2025, 14:01 With the diagbox you can test, but you need some assistance, because diagbox only keep it for a few seconds.
Greetings,
Kees.
Can you describe the procedure a little bit? Do i need to access the stiffness regulator also?
,,- after rebuilding the steering rack, i have a vibration that could be feel even in the trunk, all 3 engine mounts seems to be ok."
What do you think about this? The vibration can be felt only in P, D and R, in N it's gone. I can feel the vibration and loud noise all over the car especially in R with the steering wheel turned to max. It might be a torque converter problem or it's not the case?
Thank you!
Kees
x 148
Unread post by Kees »
Start with the section Troubleshooting, not repair, than the part suspension and find the section for command to test the stiff regulator at front. Stop the engine and let somebody stay at front, he can listen if he hear the click and push down the front.
You see on the screen if the time is running out, then you can repeat it again.
This is also for the back stiffness regulator.
Greetings,
Kees
lcwin
x 9
Unread post by lcwin »
GolfMk1Vr6, Sorry to hear you r still having issues. I suggest you look into the post I go about checking the sphere conditions in sport and normal setting.
Suspension bushes and engine mountings I recommend original or known high quality ones. Or you get good quality used original ones. Most bushing is DIRECTIONAL and if position wrongly makes the car handles badly. Tighten lower arms at ride height is very important. Tyre pressures will also affect vibration at idle.
Sorry I didnt reply the last time as I hardly come over to this forum
aerodynamica
x 215
Unread post by aerodynamica »
GolfMk1Vr6 wrote: 21 Apr 2025, 13:03
- stiff suspension, even after the 7th front center sphere was regassed. I noticed that when it becomes stiff, the vibration i was talking about is also present, it's a noisy vibration, it sounds like the engine is running at over 1000 rpm at idle, but it sits constantly at 900 rpm.
Hiya, sorry you're still finding these problems. I've had similar apart from the stiff suspension. Not sure if this will help with the vibration but I was getting a vibration similar to yours in the weeks after rebuilding the steering rack and this week I checked the lower torque stay where it meets the subframe and found that although the bolt was 'tight' there was looseness found at the bushing. I found that I could continue to tighten the bolt until the looseness went away. It was barely perceived.
It's likely I did not tighten this to the correct torque because I didn't know the value. And you can't get a torque wrench in there anyway. Cut to the end: the vibration has ceased and I I'm certain this was the reason. Just sharing what I found this week.
Graeme M
GolfMk1Vr6
@aerodynamica
Do you mean this bolt is not tightened enough? Is it necessary to remove the subframe again in order to be checked? Thanks!
aerodynamica
x 215
Hi, yes that bolt. However that picture is a different model to mine. On mine the bolt is horizontal, across. The larger rubber silentblock is on the lower casting of the engine (possibly part of the driveshaft support bearing).
If yours is like the photo then likely this bolt was not loosened. Instead perhaps the one at the other end of the torque stay.
Graeme M
TinkyWinky
Unread post by TinkyWinky »
Kees wrote: 25 Apr 2024, 07:09 It's not difficult to remove the front stiffness sphere!
You need to remove the left drive shaft and beneath the subframe the 6mm bolt with hold the airco tube.
And then with a long chisel you can hammer it loose.
I did this already a few times with different car's
Greetings,
Kees.
Hi Kees,
I'm planning on doing this on my C5 2.2 2014 Tourer. Just wondering where the 6mm bolt holding the aircon is located? Is it the red one i'm pointing at in picture or is it somewhere else further down?
Cheers
Kees
x 148
No, when you follow the tube from the front on the left side, you find the place where it is mounted by this bolt on the subframe.
michok2
Unread post by michok2 »
I'm planning to remove this sphere as well, but I have a couple of questions, if you don't mind.
This is a 6 mm Allen bolt. I was able to remove it quite easily—I even removed two of them, so the AC cable was really loose. But still… this window looks so tiny.
@TinkyWinky, the bolt is hidden near the driveshaft. I think that's the one Kees was talking about, right?
remove wheel and you will see it easily.
Kees
x 148
Did you remove the left drive shaft? It's necessary to gif room for your hand, and you have to hammer the sphere loose with a long chise from the left side.
michok2
@Kees, @Kees not yet, Sir. I’m preparing mentally for this task :) But the main question is: how much do I need to bend the AC line, and do I need to remove it from the plastic clip/cover that holds it in place?
Should I bend(ac line) towards the sphere?
Kees
x 148
I can't tell you exactly, in the past, I only removed the one M6 bolt under the subframe, you just have to see if you have enough room for your hand.
