PSA NAC RCC Updates
Julio
Re: PSA NAC RCC Updates
My Car is CITROEN C4 GRAND PICASSO 1.2 PURETECH S&S INTENSIVE 2015
vin VF7**************[VIN obfuscated, can be read by forum staff]
please let me know the Nac WAVE and if you have the update send me the link, please
- x 6945
@Julio: Sorry you do NOT have a NAC / RCC system. You have a SMEG Unit, so I cannot help.
Maps for the SMEG system are chargeable by PSA, and are available from their website. Here is the Spanish site for Navigation:
https://www.citroen.es/buy/map-update.html
- x 6945
Mirror link is no longer supported! If you update your older phone's operating system with the Mirror Link App installed it will no longer work. Android Auto is the replacement for this, but you need to ensure your Head Unit firmware is up to date.adidas levy wrote: 21 Oct 2024, 07:37 Hi,
I have just bought a Xiaomi 14T.
At first, I thought that the issue is with the cable.
Bust as I dig more about this issue I come to realize that the BOSCH multimedia does not support Android 14...
That's because the Mirror link software on the phone is updated. and at least from what I read, Mirror Link is supported 3 versions backward.
Anyway, I'm looking for a W/A to this issue.
As mentioned, I only support PSA vehicles with NAC / RCC systems, which excludes Opel / Vauxhall vehicles.
OnlinePaul-R
- x 1940
@Julio - check your private messages.
Lenken
My VIN VF7**************[VIN obfuscated, can be read by forum staff]GiveMeABreak wrote: 13 Oct 2024, 20:48I'll need your VIN to check version and whether you have WiFi on-board for authorisation of updates.Lenken wrote: 13 Oct 2024, 16:41 After downloading update "21.08.90.52_NAC-0" and trying to update my screen, a message came up saying that the update is not compatible with my software. What to do? I logged in with my chassis number so it should fit.
Lennart
- x 6945
Ok, so you have on-board WiFi, but if the signal is bad where you are, it may not be authorising the firmware update. In this case, use the included Licence file. Instructions on how to use are in the third link below.
Firmware Version 21.08.90.52_NAC-r0
Lenken Licence File
Instructions for Updating NAC or RCC Firmware, Maps & Licences
Lenken Licence File
jermy
Hi, I cant update my car with neither MyPeugeot app nor PeugeotUpdate. (reaching from Turkiye)
App seems cannot even access the version data on car.
Can you help me?
I'm not even mentioning the lack of wifi connection, parking assist, voice assistant, live traffic data and many more.
Thanks in advance.
Can you help me?
Thanks in advance.
- x 6945
No, can't help you - this thread is for NAC / RCC units, which you don't have - you have an IVI. You will need to take it back to the dealership as a lot of these are faulty.
Wukkar1
Hi guys, can anybody help me with exactly the same issue as this? I have a 2018 DS7 and I've tried the updates listed above but nothing works!
- x 6945
I've merged the previous thread into the normal PSA NAC / RCC updates Thread.
@Wukkar1: If you need help you need to provide your VIN and specify what updates you are having trouble with - Firmware or Maps?
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
- x 6945
Lennart, please don't send private messages for technical help - it does say this clearly in the signature strip under my posts, as I won't respond to them - please keep all posts for help in the forum.GiveMeABreak wrote: 22 Oct 2024, 09:29 Ok, so you have on-board WiFi, but if the signal is bad where you are, it may not be authorising the firmware update. In this case, use the included Licence file. Instructions on how to use are in the third link below.
Lenken Licence File
I can tell you that your issue has to be something at your end, as I have the same vehicle with the same system and the same firmware working perfectly.
You should put up a picture of the content of the USB after you have extracted the firmware to the USB and the licence file so I can see the files and the structure on the USB. Use the FULL EDITOR & PREVIEW button, then attachments, then browse your phone or PC for images, select all required, then upload and then use the PLACE button to insert them in your post.
6511cts
MyCitröen app says there is an update, but can't download (6_0422_23.3I37.1).
Can you help me?
Can you help me?
Reason: Moved to Correct Forum
- x 6945
@6511cts: You'll need to provide your VIN.
bee
Hello @GiveMeaBreak, and thanks for everything you've done for the French car owners.
I have a 208 Allure Selection (2023 - pre facelift) with a RCC 7" unit. The firmware installed on it is 23.3I37.1, which I believe is the latest firmware for Wave 3 units.
As far as I understand from earlier posts, it is possible to upgrade it to Wave 4 by what you call "bridging", but before that I want to know if the Wave 4 firmware is more recent or not. And if it is, can you provide me the files and path to upgrade?
VIN is VR3**************[VIN obfuscated, can be read by forum staff]
Best,
Best,
- x 6945
Hi.
This is not relevant to you because you have an RCC (non-navigation) unit. The Wave 3 / Wave 4 unit pathways are only for NAC units, not RCC.
So you already have the latest firmware installed if this is your screen shot above. There is no later version and these units do not cross over to Wave 4.
