DoneGiveMeABreak wrote: 02 Aug 2024, 13:21We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.trollkarlen wrote: 01 Aug 2024, 12:09 Oki, thanx for checking
Is this the oe number for front coil even for my vin ?
It fits the other 3008, but maybe the hybrid4 is heavier?
PEUGEOT
9815469280
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution (Min. ยฃ10 / โฌ11.48 or equivalent) to the Forum.To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Issue in a hurry Peugeot 3008 hybrid
trollkarlen
- x 4
Re: Issue in a hurry Peugeot 3008 hybrid
trollkarlen
- x 4
This does not cover dual battery setups like in my car. At least not from my understanding. But the trunk info was helpful. But the order and so on is not clear. Also does the car go to sleep with the boot up?Paul-R wrote: 01 Aug 2024, 14:30 Battery disconnection and reconnection procedure.
viewtopic.php?t=61997
My car tries to lock i self every minute or so independent of the doors or trunk being open. Does not look stock to me and can't find any setting to turn it off in the menus.
PS.
The car used to be an emergency vehicle so maybe some thing set especially for them?
It has sirens, lights and everything still attached
- x 6947
Thanks for your Forum donation.
The BSI reset is really intended for standard vehicles, not PHEV vehicles, although may still be relevant in some parts.
Can you explain what you mean by
If so,
(1) Engine Ignition Coil, part: 597091, ยฃ66.83
(2) Engine Spark Plug, part: 9830941680, ยฃ30.62
Are you referring to the engine ignition coil?Is this the oe number for front coil even for my vin ?
If so,
trollkarlen
- x 4
Sorry i was a little bit unclear, was in a hurry.
I ment the front coil(spring) in the suspension left to be exact
- x 6947
Ok, but just for future reference, please direct all parts requests to the official members parts thread here:
That thread is only for parts requests, not technical queries and ensures that they get prioritised as staff may not pick up requests outside of that thread.
(1) Front Suspension Spring, 1 Purple, + 1 Yellow + 1 Green, part: 9815469280, ยฃ148.33
trollkarlen
- x 4
Thx A lot will do that.
trollkarlen
- x 4
Its coolant change this time in the service schedule but cant find anywhere about what coolant to use or the capacity of it. Anyone got some input ?
Details about the car
Fuel:
Petrol/Electric
Capacity (l):
1.6
Engine:
Hybrid4 (M45GBU)
CCM:
1598ccm
KW/PS:
220kW/299PS
Year:
10/2019-0/0
Engine Code:
5GB (EP6FADTXHPP); 5GB (EP6FADTXHPA)
Fuel:
Petrol/Electric
Capacity (l):
1.6
Engine:
Hybrid4 (M45GBU)
CCM:
1598ccm
KW/PS:
220kW/299PS
Year:
10/2019-0/0
Engine Code:
- x 6947
The stuff used is Freecor DSCAntifreeze which is available in both 'ready to use' or concentrated versions in different quantities - available from your dealer. I don't have the technical info on this engine sorry, so can't currently provide you with quantity of coolant or procedure, sorry. We can only help with parts, part diagrams and pricing - not technical procedures unless members happen to have them personally.
trollkarlen
- x 4
Thanx for the info, found the spec(PSA B71 5110) of the antifreeze from the brand. In the good old days all the volumes where written in the user manual for everyone to read
Do Anyone know a good way to get a high beam signal on these cars, is it even possible on the outside of the front lights?
- x 6947
Not sure what you mean regarding the lights?
trollkarlen
- x 4
I want to install extra highbeams/lights and want to get the highbeam signal(12v power) to connect to the new relay. But dont know a good place to get the signal from. And maybe the front lights are connected directly on the can bus and reacts purely on can messages and not any 12 signal(power or ground) to enable the highbeam.
- x 6947
I can't advise on this, but probably not a good idea as the lights are linked to other systems like the auto dipping, auto lighting, and the camera etc. and all CAN controlled. I suspect the main relays for these will be embedded inside the engine fusebox and they may also have separate supplies - but I can't confirm this. With these modern vehicles I wouldn't recommend tapping into any of the circuits for risk of upsetting things.
trollkarlen
- x 4
Oki, thanx
trollkarlen
- x 4
The front seat is pretty badly worn and i found a new front seat for a good price. The issue is that its electric and have massage, my car have manual seats. Can i connect the chair as normal and everything will work ?
I guess most will it will just need power. Maybe i have to enable the massage functionally in the BSI ?
- x 1475
It is probable (but not certain) that your car doesn't have the extra wiring for the additional seat functionality. This would leave you with a seat that cannot be adjusted.
