So the brakes on this (new to me) C3 aren't functioning properly - you can feel the pressure when you first press the pedal, lets say you depress it to 50% and the brakes are engaging and it feels normal, but then after a second or so the pedal sinks further and you have to press quite hard to get them pressurised again.
I bled them with new fluid and the level wasn't low so I'm ruling out a fluid leak. I suppose there could still be air in the system at a place where my bleeding didn't clear, but after a quick google I've seen some suggestions that this could be an issue with the seals on the master cylinder.
Can anyone advise on whether this sounds likely, and if so, how easy is it to fit? I can pick up a second hand one for <£30 and am pretty competent with mechanics but I haven't worked on car brakes before. Are there any diagrams of the brake system knocking about?
Also worth mentioning that the MOT advisories showed "rear brake hose slight corrosion to ferrule" and "rear brake pipe corroded, covered in grease or other material".
Any advice much appreciated thanks
C3 (2004) - Brakes "sinking pedal" feeling - new master cylinder?
mowgli
Re: C3 (2004) - Brakes "sinking pedal" feeling - new master cylinder?
There's a couple of threads about this, try here fro a start.
viewtopic.php?p=771301#p771301
PaulC5
- x 705
I would not bother with a used master cylinder, it may be no better or could be worse than the existing one. In the link above it mentions needing a diagnostic to bleed the brakes so if you do not have access to the equipment it will need to go to a dealer so it might be better to get them to fit the new part as well, that way you will get a guarantee. When checking the pedal do it with the engine off to see if the pedal still sinks since on some cars the pedal effort and how far it sinks is related to how quickly you press it with the engine on.
You could also do with checking the rear brake cylinders in case they are leaking which will mean removing the drums - note new hub nuts are needed each time they are removed as well as dust caps. This will also let you check the rear adjusters are ok and that somebody has not been over adjusting the handbrake cable which would stop the adjusters working.
mowgli
Yeah that's a fair point, I'll look into somewhere to get a new one. I've just read the bit about a primary and secondary system to bleed, the secondary needing diagbox - I did actually check and follow the service manual which basically described a normal bleeding procedure, so I'm not sure the 2-stage procedure described is relevant to my 2004 C3 (his is a 2012 C5). Hopefully thats the case as I don't really have the money to take it to a dealer.
Good point about checking it with engine on and off, I'll do that. And I'll look into removing the drums thanks!
Armidillo
- x 274
Does it have ABS? As the linked thread explains, ABS & ESP are quite tricky to bleed properly, but it's obviously essential to get it right.
Another related issue - apparently ABS blocks can leak internally, giving symptoms similar to what you are describing.
mowgli
I don't think it has ABS, based on the fact that when I emergency brake, the wheels lock up :') Straight after an emergency brake test, the brakes are almost useless for about 10-30 seconds - i.e. I can press the pedal almost to the floor with very little resistance.
So, with the engine on, pressing the brake pedal is easy at first and I can hear air moving somewhere in front of the passenger side dash. It sounds like a hand pump/air moving between chambers in a suspension system (brake servo perhaps? although the noise doesn't sound like its coming from directly in front of the pedals which is where I asssumed the servo is). Once the pedal gets to about 50% it stiffens up a bit and the brakes engage. This is pretty consistent so when driving its at least predictable. Once stationary, the brake pedal slowly sinks further but the brakes are still engaged.
With the engine off, at first there is the same easy-press until 50% and moving air noise, but with each press the system increases pressure and eventually there is no air-moving noise and the pedal has resistance from the top.
- x 5678
If it has ABS then there should be an indicator light up when the ignition is turned on, should then go out after a few seconds if the system self-tests as being functional.
ozvtr
- x 256
I have found the C3's brakes to be hard and "snatchy". That is; it takes very little pressure application of the brake peddle to get the car to stop. And very little travel of the peddle to do so. It feels quite hard.
If the peddle feels "spongy" or there is no feel to it, then something is wrong.
If the fluid level in the brake reservoir is NOT going down then it might be an internal leak of one of the circuits of the master cylinder. It's not leaking fluid externally. AS you say there is no brake application for 50% of the travel that's another indication of one if the circuits failing.
It could also be the front pads and/or the discs worn beyond limits. They would need to be worn way beyond the limits but that's not beyond the realm of possibility.
The ABS module can be seen way down the bottom of the vehicle, under the near side headlight. The 6 brake lines can clearly be seen coming out of the hydraulic block. There is also a vinyl bag over the electrical connector. If it's not there, then you don't have ABS.
I have seen unscrupulous people blank out warning lights on instrument clusters so that the light never comes on (well it cant be seen).
IMHO you could roll the dice and try a used master cylinder. If it's cheap enough. I bought an air conditioning compressor for my son's utility for 20 pound! It runs perfectly!! Best deal I ever had! Having said that, we are talking about the braking system and it's safety critical!!! You don't want it to fail....EVER!!
It's your choice.
It's your choice.
ozvtr
- x 256
The service documentation doesn't mention requiring a LEXIA to bleed the ABS system. It is needed for the ESP system.
Air bubbles should be located in the upper part of the two pipes from the master cylinder. So just pumping the master cylinder should work them back up into the reservoir.
Looking on line, a brand new master cylinder doesn't look that expensive?
StealthBastard
Hey.
Hope you dont mind me waking this old post.
Did you figure out what was the problem?
My C3 (2009) has similar symptom and I was not yet able to figure it out.
System has been bleed, rear drums fully replaced, master cylinder replaced.
I don't see any change in brake fluid level, and when a procedure is made it seems to improve things for a while, but it could be just placebo...
PaulC5
- x 705
When you fit the rear drums did you set the adjusters so the drums just touched the shoes when spun ? Also the hand brake cable should be set so the shoe hand brake levers are against the brake shoe metal - if not the auto adjusters do not work. Then pump the brake pedal a lot of times with the hand brake off so the shoes are fully adjusted. If this is not done there can be excess travel of the brake pedal.
Did you do the diagnostic to bleed the abs unit ?
StealthBastard
The complete drum system was replaced in a local mechanic, but the symptoms were there before, that was already trying to fix the issue. I don't feel like that might be it because when I do brake hard, the brake pedal does not need to go down that much, only if I apply the brakes "softly" does it sink quite quickly.PaulC5 wrote: 12 Jan 2025, 21:23 When you fit the rear drums did you set the adjusters so the drums just touched the shoes when spun ? Also the hand brake cable should be set so the shoe hand brake levers are against the brake shoe metal - if not the auto adjusters do not work. Then pump the brake pedal a lot of times with the hand brake off so the shoes are fully adjusted. If this is not done there can be excess travel of the brake pedal.
Besides bleeding the brakes myself, I also requested in one of the trips to the mechanic to fully bleed it. Is there a simple way to bleed abs, or are specialized tools needed?
Thank you.
I've posted this a few times, It's not a European car but the procedure is much the same, you can do it with the Citroen diagnostics tool or most of the others. I borrowed one the same as the guy in the video used from a neighbour to do my C5.
ozvtr
- x 256
For a 2009 C3 there is no special procedure for bleeding the brakes. UNLESS the car has ESP!
If it has ESP you will need a LEXIA or appropriate scan tool.
