need to buy clutch full kit
Forum News, Announcements and any issues you're having with the forum
Chris1974
Unread post by Chris1974 »
Hello people,
I was wondering could someone help me out here, clutch in my 2013 Peugeot 3008 2.0 hdi
I was quoted that the new clutch kit would cost me 1000 euro and an additional 200 for the work.
I spent some time online but I don't know which one is suitable I have to be sure for the right one , can someone here help me by i provide him the vin number thanks
x 6956
Re: need to buy clutch full kit
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or additional information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Chris1974
donation done
Chris1974
vin number VF3**************[VIN obfuscated, can be read by forum staff]
Reason: Removed Superfluous Info.
x 6956
I've removed all that additional info, I don't need anything other than the VIN. I'm awaiting confirmation from a colleague and then I'll deal with your request shortly.
Chris1974
thanks by the way also i need timing belt to change Water pump and timing belt full kit [-o<
x 6956
Clutch Kit
(1) OEM Original Part Clutch Kit, part: 1611271880, £617.82
(1) Cheaper Peugeot Clutch Kit, part: 2051R4, £338.80
Dual Mass Flywheel
(11) Original OEM, part: 9800982980, £904.91
(11) Standard Exchange Flywheel, part: 1613939080, £558.66
(13) Bolts (all 8 must be changed), part: 1682800980, £1.57 each
Timing Kit
(15) OEM Original Kit (A+2+4+5), part: 1613561780, £368.09
(15) Cheaper Peugeot Kit, part: 1638073480, £142.42
Note Flywheel and Clutch kits will also require a deposit, refundable on return of the used part.
Chris1974
i found this on amazon can you tell me if this fit? If I'm asking to much no problem but i would appreciate your help
https://www.amazon.de/-/en/gp/product/B ... I1N4&psc=1
x 6956
Hi. I only deal with PSA original parts for which I've provided above which are available directly form the dealer. I can't speak for any after-market suppliers or parts unfortunately, for the very reason that they may be incorrect, faked, won't fit, poor quality etc.
You can of course use the part numbers I've supplied to locate an alternative from another supplier, but you will need to direct any queries concerning the part to them. :wink:
It's why we provide this optional service, so that people have the correct part numbers for their vehicles.
Chris1974
is it worth it to to change from dual mass flywheel convert with a solid one? a friend tell me there is a way
x 6956
Not recommended.
The DMF is there for a reason - to take out the torsional stress. If you remove this you have to rely on the solid flywheel conversion kit to do the same job and I personally do not think it can resolve this 100% despite the claims, otherwise all manufacturers would be fitting them as standard.... which should tell you something. This would also reduce the vehicle manufacturing costs, so there has to be a reason why the DMF is there. All that torsional stress has to go somewhere and I'm sure it would therefore put additional strain on other components in the gearbox etc.
Like anything though, it's a personal choice if you are convinced enough by the sales pitch of the conversion kits....
x 2341
Unread post by MattBLancs »
Discussion on Single Mass Flywheel Conversions here:
viewtopic.php?p=744061#p744061
x 6956
This chap gives a good explanation of the problems that are not always discussed concerning solid flywheel conversions. This is the link, then click on the video (I can't embed the video directly):
https://www.automotivepowertraintechnol ... sions.html
Chris1974
hi me again, i need help according to the part numbers Standard Exchange Flywheel, part: 1613939080, and OEM Original Part Clutch Kit, part: 1611271880, i found this VALEO 837119 – clutch kit can someone here verify please
x 6956
You'll need to verify it with Valeo, we can only provide OEM part numbers here.
