C5 2012 - P0928 Error
Karolis Vansevicius
Re: C5 2012 - P0928 Error
1642 is located in passengers side in the glovebox?
Karolis Vansevicius
Sorry for dumb questions, citroen dealers are available only in 1month so instead of just waiting, I’m trying to collect as many information as I can
- x 6956
No, the gear leaver blocking actuator (1642) is located where the BSI is as you can see below. The BSI is still in the same location on Left Hand Drive Models (on the left - Driver's Side). It is not easy to get to on a LHD. On a right hand drive it is in the same place, but that would be the passenger side for us in the UK.
- x 6956
You first need to remove the oddments tray by gently partially lowering the lid and unclipping it at the lower supporting legs. This will reveal the screws. You can then remove the trim surround, and you may also need to remove the Driver's Steering column Airbag (for the driver's knees), but you may be able to access what you need without doing this - depending on access.
This should give you a good view of the BSI - but I suspect the relay will be behind it no doubt.
Karolis Vansevicius
Hi there again, electrician tried to get that error code p0928 and it was succesfull after moving out 10A fuse on this unit:
9675877980.
After moving out that fuse, we got that error and cannot move gears. So it could be BSM unit problem?
9675877980.
Karolis Vansevicius
It’s F7 fuse
- x 6956
F7 in the Engine Fuse Box (PSF1) is the gear lever blocking actuator control relay automatic gearbox - ECU and electrohydraulic block automatic gearbox - electrohydraulic power steering.
If that was faulty, you wouldn't have any power steering....
Karolis Vansevicius
Yes, but after removing it, we received the same P0928
- x 6956
Well of course you will as you have removed the power from it.
Karolis Vansevicius
Ok, repair shops did not found any issues… but I’ve already found a trick, which helps . When I press break pedal several times and start the ignition - I get no errors. If I start ignition after longer time without brake pedal pressed - I get error… strange…
- x 6956
Maybe you have a faulty brake switch...
Karolis Vansevicius
Brake light switch or these is another one? Maybe could you give me part number? :/
- x 6956
Yes brake light switch, as the foot has to be on the brake pedal to allow Parking position of the auto gearbox to be moved from 'P'. So just a thought.... but as for parts, please see below from the 'Parts Thread'
viewtopic.php?t=69962
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
BSI Reset / Battery Disconnect / Reconnect Procedure
A response to your question by a Forum Admin requiring parts or additional information requires you
to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum.To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Karolis Vansevicius
Bu when the error exist, brake lights turn on
bahcekapili
- x 9
Same problem with P0928. My VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
My battery is new. Before battery change i got lots of errors code starting with U code. Now all have gone but P0928 stay and unless i clear fault it is impossible to engage shift
