C2 1.4 HDi '06 ABS Pump - "Is this correct" check?
NorfolkVroom
x 5
Unread post by NorfolkVroom »
Hey there to whomever reads this.
So I have a 2006 Citroën C2 1.4 HDi and the ABS light comes on.
Now it did this last year, then made a sound like someone clearing their throat, and the light went off for 7 months. :-D
It has recently come back on sadly. :cry:
After some searching on these here forums, I found this: viewtopic.php?t=60829
Now my part has the same codes as in the link, and it's the same model car, so I know the part number is 9662150680 / 4541FX.
Now, I have found these two:
https://www.ebay.co.uk/itm/225514483036 ... media=COPY
And
https://www.ebay.co.uk/itm/125654028231 ... media=COPY
Would either of them work?
(I know the second ends in 380 rather than 680, so I'm guessing it's a no-go, but thought I'd ask about it anyway.)
For some further information; two error codes come up: P1351 $07e8 and P1351 $07e8pd
Thanks!
x 6946
Re: C2 1.4 HDi '06 ABS Pump - "Is this correct" check?
Fault code P1351 has nothing to do with the ABS. P1351 relates to the glow plugs and or glow plug heating relay.
If you need an original, genuine part number, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
NorfolkVroom
x 5
Could that result in a "crossed wire" so to speak, and one is causing the other to appear as a fault? My car wouldn't start the other day, and the central locking wouldn't work. That threw me for a bit, but it turned out to be a blown fuse (engine bay fuse box) for the ignition causing both.
As I said, I've already got the part number etc from here, I just wanted to check if either of those linked parts would therefore be a match.
NorfolkVroom
x 5
Could I get the part number for the ABS pump to check I have indeed got the correct number, and could I also get the part numbers for the glow plugs and glow plug relay please. Cheers
x 6946
Hi and thanks for your Forum donation. Sorry it's taken a while to get back, it's been a busy day on the Forum.
Ok, so here you go
Pre-Heating
NGK Plug part: 596079, £24.23
Beru Plug part: 5960F9, £32.76
Citroen Cheaper alternative Plug, part: 1616056980, £13.24
Glow Plug Pre-HeatingUnit, part: 9645668680, £94.88
ABS
Unfortunately, none of these ABS hydraulic blocks are available from Citroen now due to age and supply, but here are the original part numbers for the ABS Hydraulic block to aid in your second hand search.
Unconfigured (Required coding after fitting) part: 4541FX.
Exchange unit, part: 1682607180
Configured Part (when these could be ordered configured to the vehicle), part: 4541 FY
Any future part number requests, just add a post on this thread:
viewtopic.php?t=69962
NorfolkVroom
x 5
Ahh cheers for that. That's okay, I thought it might simply to do with it being Easter.
Now with the ABS block, in my link to a 5 year old thread on my original post you said that if the ecu is kept, no coding is required?
One last bit; how do I convert these company specific part numbers to part numbers suitable for generic etc?
Thanks!!
x 6946
As for the ECU, yes, if you retain that, you won't need to code it.
As for the part numbers, these are official PSA part numbers and there isn't a simple way to match them up unfortunately, so you'll just have to search on the the exchange part number (1682607180) and you'll get plenty of results. Sometimes suppliers provide the PSA part numbers too, but they can be unreliable as their emphasis is to shift them.
NorfolkVroom
x 5
Thanks for that, I'll have to see what happens once I change some parts about then.
NorfolkVroom
x 5
Hi so this is a follow up.
I purchased a replacement glow plug relay (number matching the above - 9645668680), and after the fiddly mess it is to actually get to the relay, I unplugged the one already attached.
The one that was already plugged in does not match the above number. Instead it's 9640469680.
For now I've just put it back, but I have no idea what to do. Is the part that is in already the wrong part, and the possible cause of my ABS light coming on (but with no error codes), or even after giving my VIN is the part number I was given wrong (I'm inclined to believe that's the unlikely one of the two)?
Also the part that is in has two large pins, while the new part matching the part number has only one large pin.
I'm going to attach pictures of both.
Thanks!
New matching # relay
Current relay
Current relay
Current relay
Current relay
x 6946
Hi
So the 9645668680 part number is a replacement part for the originally fitted Glow Plug Relay. In other words 9645668680 is the superseded part number.
Your original Cartier relay (9640469680) was the correct original relay, (Citroen part: 598140), but it's been replaced with the new one. So nothing to worry about on that front.
NorfolkVroom
x 5
:) Ahh cheers for that then.
