Peugeot 207 1.6hdi Everything about.
Huskyxantia
- x 804
Husky.
Huskyxantia
- x 804
Re: Peugeot 207 1.6hdi Everything about.
So i did a px my old 307sw 2002 reg for a 207 1.6hdi 2010
Reason ? i wanted a lighter car smaller engine lower tax so ive cut my road tax nearly £200 pa halved my emissions & lowered my insurance , hope ive done the right thing
I will post here about everything re this car.
Was told the fluid pouch needed changing
Diagbox informed me it had 200mls left so new pouch ordered and fitted now ecu reads 1.1L
Due to the mileage it had to have 100mls injected into the dpf
Which was done taken for an hours run at a constant 50 @ 2500 rpm , dpf read clean from 80% before this was carried out
Miles 128000.
New Eolys fluid pouch fitted programed & primed date,4.4.23
Pervious bag was split & made a lovely mess which was fun to clean half a box of latex gloves used too.
Miles 128000.
Husky.
Huskyxantia
- x 804
How to , different car same procedure
Husky.
- x 2233
Looks smart
2010 = I'm not sure if that is new enough to be after the switch to 8 valve DV6 1.6 HDi, or the original 16 valve variety. I think also the 207 could be had with it in both 90bhp and 110bhp variants (of either 8 or 16v units)
But if the 16v then check the injector clamp nuts aren't loose (and possibly follow my experimental M7 Nyloc nuts alternative to the standard nuts of you like)
Huskyxantia
- x 804
This is 92bhp also modified turbo oil feed pipe the fuel filter has a cartridge that costs just 17£ & it on the rear left of the engine it drives nice feels bigger than what it is and is much lighter than the old 307sw i px against this , i did well with the 307 and it payed me back very healthy & i say thanks to the 307sw you was a good car
Husky.
Huskyxantia
- x 804
Where did you purchase the nyloc nuts matt
Husky.
- x 2233
EBay, could not find them locally.
Check it's the 16v though - I've no direct experience but think the injector mounting arrangement is different on the later 8 valve version.
Just had a quick look, e.g. https://www.ebay.co.uk/itm/124756205059
£2.94 for ten of them (two per injector so need 8 - so a couple of extra to drop somewhere inaccessible in the engine bay!
Huskyxantia
- x 804
I've a service to do soon so i will take some photos of the engine then pop them on here.
Husky.
Huskyxantia
- x 804
My clamp bolts are like my old 2.0hdi type
Bottom caption should be for the top
Part service today was beat by the rain
Air & fuel filter done plus checking of the dpf all good.
Oil change when next dry.
Husky.
- x 2233
Ah yes see what you mean, a Torx head bolt rather than an Allen key head nut
Huskyxantia
- x 804
So 207 needs new gear box lip , drive shaft oil seal , why do people change the clutch kit but hardly renew the drive shaft seal ? Lazy , stupidness or stulazyness ?
Husky.
Huskyxantia
- x 804
Rear brakes. Drum type . Can or is it possible to change the drum type to disc ?
Husky.
Huskyxantia
- x 804
Video library
Husky.
- x 2233
Just to check - is your 207 1.6 a five speed manual?Huskyxantia wrote: 09 Apr 2023, 12:43 So 207 needs new gear box lip , drive shaft oil seal , why do people change the clutch kit but hardly renew the drive shaft seal ? Lazy , stupidness or stulazyness ?
If so it'll be a BE gearbox. I'll look up the seals in a bit as I've changed them on various BE gearboxes previously.
They are available on eBay, very quick search, might not be the cheapest:
https://www.ebay.co.uk/itm/125728729636
£6.99
Note there's 3 as includes the input shaft seal, but obviously that's much more involved to change! (Gearbox off)
It's possible to get driveshafts in and out without wrecking these seals with care. Unfortunately the care bit is in short supply!!
Huskyxantia
- x 804
MattBLancs wrote: 09 Apr 2023, 15:07Just to check - is your 207 1.6 a five speed manual?Huskyxantia wrote: 09 Apr 2023, 12:43 So 207 needs new gear box lip , drive shaft oil seal , why do people change the clutch kit but hardly renew the drive shaft seal ? Lazy , stupidness or stulazyness ?
Yes 5 speed.
£6.99
It's possible to get driveshafts in and out without wrecking these seals with care. Unfortunately the care bit is in short supply!!![]()
Husky.
