Dear FCF,
i would like to thank you for all the info that i found here, leading up to me buying a xantia.
I would like to service the suspension, and start by changing the front accu. sphere and rear anti sinnk sphere.
I am having trouble with ordering and identifying the OEM part number for my car, so I would like to ask for your help with my problem.
I am aiming for I.F.H.S. spheres, as i read online that they are the best to go for.
My VIN number is VF7**************[VIN obfuscated, can be read by forum staff].
Kind regards,
Luka ?ureš from Croatia.
Sphere identification help
lux
Not my circus, not my monkeys.
Luka ?ureš, Zagreb, Croatia.
- x 6956
Re: Sphere identification help
Hi Luka
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, we now have your VIN.
lux
Thank you for the directions Mark.
I pledge my allegiance to ze BXClub/CFC.
Now, how can i access this database.
Cheers
Cheers
- x 6956
You won’t have direct access, but here you go:
Item (2) Front Rigidity Regulator Sphere. 450 CM3 75 BARS:
Citroen Original, Part: 1638043580, £118.00
Citroen Cheaper Alternative, part: 1638379780, £83.35
Item (3) Rear Rigidity Regulator Sphere. 400 CM3 50 BARS:
Citroen Original, Part: 1638043680, £99.40
Citroen Cheaper Alternative, part: 1638379880, £45.23
Item (4) Sphere & Gasket. 385 CM3 50 BARS:
Citroen Original, Part: 1638045880, £173.90
Citroen Cheaper Alternative, part: 1638377080, £83.54
All VAT Inclusive, direct from Citroen.
lux
Okay, now i understand how this goes.
Thank you for the reply.
Kind regards
Kind regards
- x 8345
When you replace the rear anti-sink sphere be aware it has a hydraulic pipe screwed into the back of it and this must be loosened and the pipe removed from the sphere before the sphere is unscrewed from its mount... Failure to remove the pipe first will seriously damage it.
Also, despite its name, this sphere has absolutely nothing to do with the car not sinking or otherwise... It is badly named in the respect! It is an auxiliary brake accumulator and was added to the system when anti-sink suspension was introduced - hence its name...
lux
Okay, so, i have trouble identifying the spheres by the manufacturer I.F.H.S.
I can't make sense of the original Citro parts reference number and the ones provided by sites that sell IFHS.
Would you kindly point the finger for me on which should be chosen.
I was trying to identify them on this website:
https://moto-dynamic.com/products,2?pag ... =%ef%80%82
Maybe i am too uptight with the IFHS spheres, if you can recommend another high quality manufacturer, i am listening.
Thanks in advance
Thanks in advance
- x 8345
Normally you don't need to know part numbers when ordering spheres...
You should always be able to do it by car model... There is nothing special about the spheres on your Xantia and any supplier, upon enquiry, should be able to supply a suitable set.
If they cannot then they are not good to deal with...
- x 1449
Have you seen https://frenchcarforum.co.uk/wiki/Sphere_Table ?
I would say that it is better to know what you want, as I have known more than one sphere supplier who would supply comfort spheres unless asked ot to.
aerodynamica
- x 215
Just to clarify: the spheres in the diagram are front and rear hydractive regulator spheres but the OP said front accumulator. I am wondering if it's the main accumulator he means? Is this for a hydractive Xantia?
Graeme M
- x 8345
OP's signature suggests he has an SX Graeme so would be a non-hydractive...
And good to see you again in this virtual world
I trust you are keeping well...
lux
That's a great table. Ordered spheres following it.xantia_v6 wrote: 21 Oct 2022, 10:35 Have you seen https://frenchcarforum.co.uk/wiki/Sphere_Table ?
Thanks a Bunch
