C2 ABS Pump
C2 ABS Pump
hi I have. citroen c2vts with faulty abs pump. Sent away for repair but if not fixable anyone know where I can get replacement part either same part number or compatible. New or used Part number 10.0960-1144.3. thanks in advance
Reason: Moved out of Official Parts Requests (That thread is for donating members requiring official part numbers)
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5722
Re: C2 ABS Pump
That doesn't appear to be a PSA or other recognised part number.
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
To Upgrade Your Membership & Donate Click Here For Further Information About Vehicle Parts and VIN Numbers Click Here |
Re: C2 ABS Pump
Have you tries the ABS centre on ebay? they have loads of variations of PSA ABS units, might be wirth a message to them.
https://www.ebay.co.uk/str/abscenter?_t ... 3561.l2563
The original Citroen part number (not found anywhere on the part) will unlikely mean anything to a breaker or second hand supplier as they normally go with the numbers on the unit itself. A brand new one would likely write the car off.
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: C2 ABS Pump
I too drive a C2 now, I found a facebook group where they seem to be breaking quite a few of them, some of those guys seem pretty knowledgeable about the C2.
