Eunice progress reports.
x 6948
Re: Eunice progress reports.
I should be fine now thanks, as each burner comes with 4 cylinders - so that will be 8 altogether and plenty for the odd power cut (and I say 'odd' hesitantly), unless they're planning to send any more storms our way - but thanks for the offer.
Lock 'n' load
x 5679
If you have one handy then Screwfix and Toolstation both have gas cylinders.
x 2938
I'm looking to buy one of those Hyundai EV car adaptors that plug into the car and give you a three pin plug outlet connector so you can use the car as a supply.
Can't find anyone supplying it yet except Hyundai with the new car.
x 1946
What type of three pin socket do you get on the adaptor? My first thought is that it's one of those blue caravan type connectors but maybe it's a Euro or British socket.
x 3298
Check on ebay for cartridges. I did a search, and found you could get 28 for around £45.
Not quite the Ford 150 Lightning but a useful solution
x 8156
Gibbo2286 wrote: 20 Feb 2022, 10:32 I'm looking to buy one of those Hyundai EV car adaptors that plug into the car and give you a three pin plug outlet connector so you can use the car as a supply.
Looking at Neil's video there Gibbo it would appear that some on board software is needed as well as the adapter. I doubt if your Zoe has the capability?
mickthemaverick wrote: 20 Feb 2022, 11:27
I have shoved a bit on the energy matters thread on what is known as "Vehicle to Load" or a socket in your car to supply appliances :-D It will more than likely become a more frequent offering, currently Hyundai Ionic 5, Kia Ev6 and yes the MGZS EV have V2L capability.
viewtopic.php?p=710052#p710052
x 3298
Unfortunately thieves are now making off with charging cables, either for the copper or to sell them on-line;
https://www.msn.com/en-gb/cars/news/own ... d=msedgntp
x 8156
Hell Razor5543 wrote: 20 Feb 2022, 12:28 Unfortunately thieves are now making off with charging cables, either for the copper or to sell them on-line;
At least if they are caught the police should find it easy to charge them!! :sulk:
x 6948
Groan....
