I should be fine now thanks, as each burner comes with 4 cylinders - so that will be 8 altogether and plenty for the odd power cut (and I say 'odd' hesitantly), unless they're planning to send any more storms our way - but thanks for the offer.
Lock 'n' load
Eunice progress reports.
- x 6957
Re: Eunice progress reports.
- x 5673
If you have one handy then Screwfix and Toolstation both have gas cylinders.
- x 2941
I'm looking to buy one of those Hyundai EV car adaptors that plug into the car and give you a three pin plug outlet connector so you can use the car as a supply.
Can't find anyone supplying it yet except Hyundai with the new car.
- x 1938
What type of three pin socket do you get on the adaptor? My first thought is that it's one of those blue caravan type connectors but maybe it's a Euro or British socket.
OnlineHell Razor5543
- x 3306
Check on ebay for cartridges. I did a search, and found you could get 28 for around £45.
- x 7164
- x 8088
Looking at Neil's video there Gibbo it would appear that some on board software is needed as well as the adapter. I doubt if your Zoe has the capability?Gibbo2286 wrote: 20 Feb 2022, 10:32 I'm looking to buy one of those Hyundai EV car adaptors that plug into the car and give you a three pin plug outlet connector so you can use the car as a supply.
- x 7164
I have shoved a bit on the energy matters thread on what is known as "Vehicle to Load" or a socket in your car to supply appliancesmickthemaverick wrote: 20 Feb 2022, 11:27Looking at Neil's video there Gibbo it would appear that some on board software is needed as well as the adapter. I doubt if your Zoe has the capability?Gibbo2286 wrote: 20 Feb 2022, 10:32 I'm looking to buy one of those Hyundai EV car adaptors that plug into the car and give you a three pin plug outlet connector so you can use the car as a supply.
viewtopic.php?p=710052#p710052
- x 3306
Unfortunately thieves are now making off with charging cables, either for the copper or to sell them on-line;
https://www.msn.com/en-gb/cars/news/own ... d=msedgntp
- x 8088
At least if they are caught the police should find it easy to charge them!!Hell Razor5543 wrote: 20 Feb 2022, 12:28 Unfortunately thieves are now making off with charging cables, either for the copper or to sell them on-line;
- x 6957
Groan....
