207cc lumpy starting.
Colin2206
- x 19
My wife's car has had lumpy starting and running, until it gets warmed up, for a while now. It is a 2008, 1.6 petrol VTI
There is a PO114 fault code that reoccurs (it is the only fault code) and the "depollution.." warning. I've change the camshaft sensors and swapped them over and it is always Bank 2. Also the associated oil valves. Cleaned and swapped and renewed spark plugs and air filter and cleaned the air flow butter fly.
However the lumpy running has got noticable worst with the colder weather. I am now thinking the lumpy running is to do with the cold engine...so my next attempt is the coolant sensor & thermostat. As for as I can make out, both are in a housing and, in theory, can be replaced seperately, although I can't find a supplier for the thermostat. I intended just replacing the lot.
Any thoughts about this and has anyone had a similar expereince?
Regards,
Colin.
Regards,
Colin.
Huskyxantia
- x 759
Re: 207cc lumpy starting.
Its hard to get a thermostate on its own as there mostly fitted in a plastic housing, have you cjecked vaccum hoses ? Head gasket ok ?
Husky.
Colin2206
- x 19
Thanks for the reminder re vacuum hoses. I'll check with a bit of loose hose tomorrow.
No signs that the head gasket is leaking.
I am checking prices for the coolant housing.
Colin2206
- x 19
I spoke to my local mechanic and he will be putting the car on his disgnostic next week, but he though that a good guess would be the timing chain. I can't find a recommended replacement interval for the 1.6 vti. Plenty about belts but not so much about chains. Given the cost involved I was wanting a more definitive analysis (which I might next week).
Does anyone know what Peugeot recommend for their chains?
Colin2206
- x 19
Update; Local garage could not get a error code to show, and had a bit of trouble delivering the car back due to uneven running! No charge even though they spent an hour on it.
I managed to get error codes over the next few days and at last began to see a pattern, problem in No.1 cylinder. I swapped the plugs around, all ok, so changed the coil (£25) and that cleared >90% of the lumpy running. But there is something still there. Also changed the O2 sensor (£50) and there is still something there. After the last test run , no fault codes generated, BUT there is still something there; lumpy when cold and occassional miss when warm.
I've booked it in for a professional scan (£72) first week in Jan, and that gives me a week before MOT is due.
Is it just me or isn't the point of onboard diagnostics to tell you what is not right so it can be fixed promptly and efficiently? This is has been going on for months now and it is old fashioned educated guesses and trial & error to get this far.
Huskyxantia
- x 759
As i have found on board diagnostics are not always true , if i haven't read this right , maf sensor ? Has that been checked if so sorry for skip reading . Have you done a bubble test ? Jar of water , pipe from water bottle to the jar and see if any bubbles appear thats an old way to test head leaks,gasket,..
Idle control valves can play up too, also dirty earths can cause some odd issues
Husky.
Huskyxantia
- x 759
Another thing and it might sound silly , could this be anything to do with the new e10 petrol ?
An old car i had well it was 10 yr old when i got it did similar and all tests revealed nothing, mine was head gasket it was just staring to weep, i did that and all was good after, but all cars are different, hope you get a result and fix.
Husky.
Colin2206
- x 19
Update.
Success. I prepared the car for it's MOT, even tho' it was still not running right. There was a persistant P014 code, which had me changing out the cam sensors, oil actuaton ? valves and cleaning the air flow valve & and sensor (x2) all to no avail. So I bought a timing kit and checked the timing and it was out by the tiniest amount and I do mean tiny. That got rid of the error code. The real interest was on start up on and the engine was very poor, due to a failed ignition coil. This seems to be the source of the persistent lumpy start and occassional miss when running. But, as I said above, no error codes until total failure occurred. Very disapointed the OBD could not pick up a failing ignition coil. I would have though a missing spark was one of the easier senarios for electronics to pick up.
Anyway, car has been running ok for a week now, although very low mileage yet.
Huskyxantia
- x 759
Congrats... nice feeling when the cars all sorted, well done.
Husky.
Colin2206
- x 19
I possibly spoke too soon.
The car hasn't been used much in the last few months (and I've changed the gearbox) but the lumpy starting still remains. Nothing like as bad as the original but still there. Also the P0014 code has re-occurred and mis-fires in some cylinders when cold. Now I have changed all plugs, ignition coils and the associated oil valves (forget the correct name). I am convinced it is an electrical fault at source. The only thing left is the wiring harness. It looks ok but I was wondering if there is a simple test I can do with a multimeter to check it or even is it feasible to replace?
We are getting to the stage were we have to think about scrapping it but my wife is fond of the car and it is solid underneath, so I am willing to give it another go.
Any suggestions appreciated.
Regards,
Colin.
Regards,
Colin.
Colin2206
- x 19
Well things have gone from bad to worse.
I was rechecking the coils and plugs; pulling on one of the new coils it seperated (taking it back on Monday), leaving a rubber over the plug, making it impossible to get the plug out. So off came the rocker cover, straight forward, rubber pulled of the plug, all ok. And when I went to put the rocker cover back on...see below
A lot of white gung.
I checked the oil cap and found some gung in it, but I had to look right at the top of the cap,in the corners, also some on the oil valves. Now I am sure this wasn't there when I checked recently. Dipstick is clean.
This looks like a lot of gung to me but maybe a small leak produces a lot?
Huskyxantia suggest earlier this might be a source of the lumpy problems I'm having.
I know this is a sign of coolant in the oil (possible head gasket failure) but I have not experienced this before, so any pointers appreciated.
Colin2206
- x 19
Huskyxantia
- x 759
This is possible head gasket failure as starting would be lumpy because water across spark plugs means no spark same as the mayo stuff , if you can or know someone get or have them do a compression test that will shine more light on the problem .
If you have noticed a lack in power over the course of a few weeks and more steam coming out the tail pipe than normal that is another sign gasket going, some don't have to over heat one of my old cars ran for a year before it went apart for the slight lack of power wasn't till i striped the head i saw the gasket had failed
Also that rich oily petrol smell , theres a small kit on ebay that uses a chemical that changes colour when the gasket has gone. Ive used them with good results.
https://www.ebay.co.uk/itm/Combustion-l ... 635-2958-0
Husky.
Colin2206
- x 19
Thanks for this.
I ordered a leak test last night.
In one way I am relieved to see a physical sign of what the problem may be (mayonase). All this OBD stuff was getting me down, as I was going round in circles and changing out parts on partial info is never the way to go. At least my spend has been modest as I had the sense to swope components around were possible and not pay dealer prices when I did fit new parts.
I fitted two new ignition coils this morning and the car reacted very badly and is throwing up four codes re. the throttle sensor, so I now have to resolve that before I can do anything else. Hopefully it is just been knocked in some way when I took the rocker cover off to access the broken ignition coil.
Huskyxantia
- x 759
I'd check the housing of the throttle body see if that needs a clean, sometimes the most simple of things suddenly stare you right in the face and the solution is found, i leave things for a day or two then go back to the car and it sort of goes right
Husky.
